Author Topic: Would a damaged DV leave error codes?  (Read 1582 times)
Offline Bennz
« on: June 29, 2014, 10:12:38 pm »
I have read the great thread about DV and PCV and learned a great deal before it got my new mk5 GTI. I took the car to dealer to do inspection per my requested items.
One of them was DV and PCV. PCV was tested by them and myself ( oil stick removal method ) and seems it is working perfectly.
However I asked the dealer if they removed DV to inspect it physically, they mentioned no because there was no error codes related to it...
So my question is, could I rely on the claim that because there is no error code the DV is okay ?
I haven't owned a GTI before and car has only done 30,000 KMs ( 2008 model ) I don't feel any lag or lack of response but again I'm no expert in GTIs.
Thanks all :)
Offline betty_swollox
  • -Receive: 29
Re: Would a damaged DV leave error codes?
« Reply #1 on: June 29, 2014, 10:17:06 pm »
Just change it
It's £30.
Dealers don't check them. And iirc it doesn't give an error code in vcds either.
Get it changed so you know it has been done  :happy2:
2010 Leon CUPRA
BCS Powervalve Exhaust
Revo Ceramic Intake
APR Stage 2
Offline Bennz
« Reply #2 on: June 29, 2014, 10:29:37 pm »
Thank you .
What is the recommended revision ? Or an after market ( higher quality than OEM)?
Something that if I go with APR Stage 1 it won't torn apart or fail quickly :)
Offline th3_f15t
  • -Receive: 183
« Reply #3 on: June 29, 2014, 11:20:37 pm »
D or G revisions are fine. An aftermarket option is the GFB DV+ upgrade, search the reviews section. :)
Offline Bennz
« Reply #4 on: June 29, 2014, 11:34:23 pm »
Is rev D not using rubber anymore? I.e lasting longer and more resistant ?
Will do a search on GFB DV+
Offline daedos
« Reply #5 on: June 30, 2014, 07:01:31 am »
Having just through this myself here is my 2p.....
VCDS - once the problem gets bad enough it will leave a fault code under engine - Boost Control Regulation : Control Pressure Not Reached. I could also hear excess turbo whistle when driving.
Rev D or G - opinion differs but there seems to be a slight preference for G. The piston in D can leak slightly and isn't as smooth. D might last longer. Both can cope with stage 1.
I went for G at £35+VAT. FYI you'll probably need to order it in first.  As a first timer it took me about 45 mins to check my Rev B currently installed. Multiple splits so looking forward to getting the G on.
http://www.mk5golfgti.co.uk/forum/index.php?topic=44709.0
Offline Nodz
  • -Given: 73
  • -Receive: 103
« Reply #6 on: June 30, 2014, 07:15:33 am »
Go for G, it seals better with the rubber the D can leak from the start as it does make a good seal. Then treat it as a serviceable part and change when needed
Offline Bennz
« Reply #7 on: June 30, 2014, 08:17:22 am »
I checked with VW and based on my VIN they confirmed I have revision G on mine from factory. Probably ask them for physical inspection when going there next.
  • -Receive: 29
« Reply #8 on: June 30, 2014, 08:32:24 am »
Mate, just change it  :stupid:??
They may do a visual inspection and yes, if there was a massive tear in the diaphragm they'd see it, but it could have a smaller tear that isn't visible
I'd rather get it changed for peace of mind....
2010 Leon CUPRA
Revo Ceramic Intake
APR Stage 2
Offline Bennz
« Reply #9 on: June 30, 2014, 08:45:52 am »
Thanks lol will do when doing cambelt :)
  • -Receive: 29
« Reply #10 on: June 30, 2014, 09:21:47 am »
Good!!!!! Lol
2010 Leon CUPRA
Revo Ceramic Intake
APR Stage 2
Offline john87
  • -Receive: 53
« Reply #11 on: June 30, 2014, 09:55:06 am »
I have a nearly-new Rev. G in the house if you want it? £25 posted  :smiley:
Offline Bennz
« Reply #12 on: June 30, 2014, 10:31:14 am »
Thanks John , unfortunately I live in New Zealand :( pretty far from you.
Offline th3_f15t
  • -Receive: 183
« Reply #13 on: June 30, 2014, 10:38:57 am »
Changing the DV is a really simple job actually, save yourself some money and get the car up on axle stands and about an hours work. Plenty of good guides on the internet, search YouTube for tutorial videos so you can see the job before undertaking it.
