Author Topic: Intake manifold flap motor???  (Read 2455 times)
Offline mk4gti-t
  • -Given: 61
« on: June 30, 2014, 01:09:57 pm »
My intake flap motor is knackered and needs replacing but cant find the exact same part number on ebay etc...
Do i need to fit 06F133482 or can i use one of the others i've found for sale, say 06F133482C?
Does the letter at the end mean anything or is it just an updated part?
Cheers.
  • -Receive: 453
Re: Intake manifold flap motor???
« Reply #1 on: June 30, 2014, 03:38:21 pm »
If your Intake manifold flap motor has a letter on the end of its part number then you should get the latest "E" revision. If it has no letter on the end then you need the same part number.
It's important as your can't complete basic setting with vcds with the wrong version installed.
Offline mk4gti-t
  • -Given: 61
« Reply #2 on: June 30, 2014, 08:25:29 pm »
Thanks for that mate. Can I get the part number off vcds or do I need to get they knackered part off to read the number?
Offline Jonny
  • G7R Owner
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,45008.0.html
« Reply #3 on: June 30, 2014, 08:41:58 pm »
I've got the exact same problem as you mate, all I did is take a photo of it to get the part number revision, its just under the manifold  :happy2:
Offline mk4gti-t
  • -Given: 61
« Reply #4 on: June 30, 2014, 09:52:00 pm »
Cheers mate ill have a look tomorow  :happy2:
It's a 06F 133 482 and I've just got one off the bay for £18  :signLOL:
« Last Edit: July 01, 2014, 02:00:17 pm by mk4gti-t »
