Author Topic: PCV and the inner workings of the system on the tfsi engine  (Read 25782 times)
Re: PCV and the inner workings of the system on the tfsi engine
« Reply #15 on: November 03, 2009, 03:12:00 pm »
so am i right in thinking that with the stage 1 fix it prevents any of the oil etc. ever touching the intake valves?
Unfortunately no.
Offline edition_30
« Reply #16 on: November 03, 2009, 03:26:35 pm »
so the only way would-be via the catch tank method stage 2?
« Reply #17 on: November 03, 2009, 05:01:51 pm »
Yup, catch can or a vent to atmosphere setup.
Offline Phil@BSH
« Reply #18 on: November 05, 2009, 08:05:05 pm »
This is correct. Thank you.
513 bhp at 24 psi. More still to come!
BSH Speedshop
info@bshspeedshop.com
Help us work with you. If we make a part that you want and it needs special Euro fitments please contact tech@bshspeedshop.com
Offline candy turbo
« Reply #19 on: November 06, 2009, 09:41:27 pm »
might fit the catch can to the s3 tomorrow can some one con firm which hose goes where ?  looking from the front towards the windscreen  left union to .............. , right union to ...................  of the catch can ???????????????/ :happy2:
Offline cupra_k1
« Reply #20 on: November 06, 2009, 11:00:19 pm »
Right fitting to side of catch can / left fitting to top of catch can is the advised orientation, although it can be plumbed in either way with no ill effect.
Offline candy turbo
« Reply #21 on: November 07, 2009, 08:10:47 am »
thats the opposite to whats said on the other thread !!!!!! :confused:
Offline cupra_k1
« Reply #22 on: November 07, 2009, 08:24:57 am »
Then why bother asking the question here and also starting a new thread if your so sure? I myself fitted my catch can as per the instructions on the BSH website but since changed after being advised by Phil @ BSH. Have you actually read through this thread? http://www.mk5golfgti.co.uk/forum/index.php?topic=8243.30
« Reply #23 on: November 07, 2009, 09:55:51 am »
....Because it is (and certainly has been) a bit confusing and because we are supposed to be here to help each other by speaking to each other a tad more politely. Not everybody manages to read every single thread and post.
Offline candy turbo
« Reply #24 on: November 07, 2009, 05:02:42 pm »
you need to chill out mate  :fighting2:
Offline cupra_k1
« Reply #25 on: November 07, 2009, 05:38:27 pm »
How do I? You asked a question and i thought i'd help by giving you the answer you were looking for, only for you to question it. I was merely pointing out that you needn't ask the question in the first place if you thought you already knew the answer and all you were going to do is doubt peoples advice.
Anyway no offence was intended and i hope the fitting of the can goes well.  :happy2:
« Reply #26 on: November 07, 2009, 05:52:06 pm »
:happy2:  Peace  :grouphug:
« Last Edit: November 07, 2009, 05:54:57 pm by RedRobin »
« Reply #29 on: November 08, 2009, 11:45:59 am »
now that i would fit to mine  :smiley:
