Author Topic: Thule aero bars  (Read 1248 times)
Offline JPW
Thule aero bars
« on: July 01, 2014, 10:17:46 pm »
Has anybody fitted these and do they have a photo?
Not sure that mine seem to sit quite like other photos I've seen.
Reflex Silver with a few toys :-)
Offline Jonneh
Re: Thule aero bars
« Reply #1 on: July 01, 2014, 10:34:19 pm »
I've fitted the non aero ones to mine and they're fine!
Where is it they don't seem to fit right? It was a bit of a faff to do admittedly and took two of us but they were all good!
Passat R36 - Corrado VR6 - Mk2 Golf GTI 8v
Offline Frenzy
  • -Receive: 29
Re: Thule aero bars
« Reply #2 on: July 01, 2014, 10:50:11 pm »
these are the areo bars. a bit of a distant photo but hopefully you get the idea...
« Last Edit: July 01, 2014, 10:56:09 pm by Frenzy »
Offline JPW
Re: Thule aero bars
« Reply #3 on: July 01, 2014, 10:56:51 pm »
Is there a guide to posting photos?
It's the pads and where they sit that I'm unsure of.
Offline Frenzy
  • -Receive: 29
Re: Thule aero bars
« Reply #4 on: July 01, 2014, 11:05:20 pm »
Use an image hosting site and simply upload your image from wherever it's saved on your computer. The image hosting site will then give you a URL which you copy and then paste where i have put the X:
(img)X(/img) - substitute [] for the curved brackets i have used in order to get the example to work.
OR
If you look at the row of icons above where you type your message there is an icon next to the Adobe acrobat icon, to its left which is the picture icon. If you press this it automatically puts ([img)(/img) in the text area (again i have used curved brackets rather than the [] you need otherwise it won't show as an example.
HTH
As for the pads... do you mean the black 'feet'? If so there are housings on the door frames of each door. You need to remove the little black nipples and keep them somewhere safe. The pointy bits of the feet then go in these holes that you've just exposed and you tighten the feet up with the key supplied.
WARNING - it's a bit of a faff the 1st time you do it so if you aren't confident and careful you can easily scratch your paint work trying to line the damn things up, so you might want to get another pair of hands to help.
« Last Edit: July 01, 2014, 11:11:11 pm by Frenzy »
Offline JPW
Re: Thule aero bars
« Reply #5 on: July 01, 2014, 11:43:39 pm »
Yep, the rubber feet on the fitting kit.
Removed the covers and the pins locate fine.
The pads just font appear to sit over the lip on the roof as I've seen on some photos online!
Offline JPW
« Last Edit: July 02, 2014, 08:22:38 am by JPW »
Offline JPW
Re: Thule aero bars
« Reply #7 on: July 02, 2014, 01:12:31 pm »
All sorted now  :smiley:
Offline Frenzy
  • -Receive: 29
Re: Thule aero bars
« Reply #8 on: July 02, 2014, 06:04:23 pm »
well done  :pomppomp:
