Author Topic: ESP/Steering light issue.  (Read 1959 times)
Offline Munzz
« on: July 05, 2014, 02:07:45 pm »
Hi Guys,
Annoying issue, me being me, I was tinkering around with the fuse board in the engine this morning and believe I incorrectly inserted a fuse into the wrong hole. Subsequently, I have two light illuminated on my dash, ESP and the steering wheel.
I can't for the life of me work out what I've done wrong, can any electric heads suggest anything or will it be a trip to the local garage!?
Below is a photo of my fuse board:
Any help will be greatly appreciated.
« Last Edit: July 06, 2014, 08:10:00 pm by Munzz »
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=sieqccf78cs2sa9j3t549o259m&/topic,19740.0.html
Re: Fuse Issue.
« Reply #1 on: July 05, 2014, 02:09:06 pm »
Go for a drive... the will probably clear.
Offline Munzz
Re: Fuse Issue.
« Reply #2 on: July 05, 2014, 02:14:23 pm »
Travelled 5 miles this morning and they stayed illuminated, I was under the impression they would clear too.
Offline th3_f15t
  • -Receive: 183
Re: Fuse Issue.
« Reply #3 on: July 05, 2014, 02:41:06 pm »
The lid of the cues box should list which fuses do what. A Haynes manual may hold clues too. Only other thing could be like the airbag lights, when the system detects a component not reporting a signal for whatever reason (disconnection a wire, for example) the default is to assume there's an intermittant fault and log/display it.
VCDS scan and clear.
Offline Munzz
Re: Fuse Issue.
« Reply #4 on: July 05, 2014, 02:55:49 pm »
I think the best bet would be to get a scan, anyone in Northampton able to offer a VCDS scan in return for beer?
Offline th3_f15t
  • -Receive: 183
Re: Fuse Issue.
« Reply #5 on: July 05, 2014, 02:57:21 pm »
Innters tomorrow, see who's going and attend yourself... :happy2:
Offline Munzz
Re: Fuse Issue.
« Reply #6 on: July 05, 2014, 03:14:54 pm »
Thanks mate, what/where is Innters!?
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Re: Fuse Issue.
« Reply #7 on: July 05, 2014, 03:33:28 pm »
Offline Munzz
Re: Fuse Issue.
« Reply #8 on: July 05, 2014, 11:46:06 pm »
GTI International  :happy2:
http://www.mk5golfgti.co.uk/forum/index.php/topic,79152.msg872300.html#msg872300
Cheers bud, won't be able to make tomorrow but have but my feelers out for a kind hearted sole in Northampton to help me!
Offline Munzz
Re: Fuse Issue.
« Reply #9 on: July 06, 2014, 08:09:38 pm »
On further investigation, I don't believe its a fuse issue but more to do with the fact I disconnected the battery.
As mentioned, they usually go off. On this occasion they haven't so I performed the generic reset (full turn left, full turn right, back to centre and drive in a straight line) although this failed to work.
I'm praying its a simple VAGOM jobby, will update accordingly.  :happy2:
