Author Topic: Sitting at traffic lights with dsg  (Read 4776 times)
Re: Sitting at traffic lights with dsg
« Reply #15 on: July 07, 2014, 11:56:42 am »
In Mandy's case it's probably witchcraft holding the car.  :wink:
Offline Bennz
« Reply #16 on: July 07, 2014, 08:48:36 pm »
But it must be some form of contact when it's in D, cause when I stop the car and it's in D you can feel the gearbox is under some form of load and when it's in N the pressure is gone and it is free.
Offline Markyed30
« Reply #17 on: July 07, 2014, 08:53:46 pm »
In n mines is at 20 hg boost in d and foot on brake it's at 18 explain that 1?
Offline xjay1337
  • -Receive: 377
« Reply #18 on: July 07, 2014, 09:15:03 pm »
Same.
Haven't measured it with VCDS but always lead to believe there is a clamping force on the k2 clutchpacks when in D.
Defo extra load on the engine as measured by vac pressure. Can hear the engine note change as well.
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #19 on: July 08, 2014, 06:30:07 am »
A little experiment for you all to try - get to a set of traffic lights, leave the 'box in D and put your handbrake on. It'll strain against the brake for about a second, and then it stops. It's obvious to me that the car is no longer being held at the bite point.
PLANS: Stage 2+
