Author Topic: Removing mk5 stereo  (Read 17047 times)
Offline Fozzie
Removing mk5 stereo
« on: July 06, 2014, 08:31:38 pm »
What sort of job is it to remove the standard stereo on a mk5 golf gt tdi?
Been told it can be a bit of a headache but will have a go myself if it's not!
« Last Edit: July 06, 2014, 09:13:03 pm by Fozzie »
Offline mk5Eire
Re: Removing mk5 stereo
« Reply #1 on: July 06, 2014, 08:55:37 pm »
Just to clarify which stereo do you want to remove? The title says mk5 but you say mk4 in the post?  :smiley:
If its the mk5, its not a headache. you just gotta watch that you dont break any clips. Im so used to it now i can whip out a radio in 10-15 mins.
http://www.golfmkv.com/forums/showthread.php?t=170712 that thread has everything you need to know  :happy2:
Offline Fozzie
« Reply #2 on: July 06, 2014, 09:13:44 pm »
Thanks it is a mk5 my mistake!
Offline daedos
« Reply #3 on: July 06, 2014, 09:18:03 pm »
Get some trim removal tools, t20 screwdriver and get stuck in. I found this video very helpful.
Offline Fozzie
« Reply #4 on: July 06, 2014, 09:53:54 pm »
Yeah I will do and great video thanks!  :happy2:
Offline anderson9
« Reply #5 on: July 06, 2014, 11:39:07 pm »
It's pretty simple, just watch those metal clips! What do you intend doing when having it out, replacing it, Bluetooth etc...
Offline J400uk
  • -Receive: 27
« Reply #6 on: July 07, 2014, 07:31:53 pm »
Be careful with the top vent as its a major source for rattles if it doesn't go back on properly!
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
« Reply #7 on: July 07, 2014, 08:26:17 pm »
also don't remove the hazard/airbag plug as you will get a fault and need it removing
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline AndyBrown
« Reply #8 on: July 08, 2014, 01:45:29 pm »
Has anyone had any issues replacing the top part of the centre vent?
It all came off and back on again with no problems except the last bit, the front won't stay down, the back sits flush but for the life of me I can't get the front sorted!
Offline mk5Eire
« Reply #9 on: July 08, 2014, 01:47:15 pm »
Is this where the rubber tray sits in?. In my experience if the front isn't sitting down or one side is higher than the other it means one or two of the clips isn't in right or isn't in at all. You should have found two clips at the back of the tray when your removed it, they sort of hold it down in place.
Sent from my iPhone that has issues.. Reception issues...
Offline simonp
  • -Receive: 38
  • No longer a Golfer
« Reply #10 on: July 15, 2014, 08:56:10 am »
Only if you turn the ignition on with it unplugged.  :smiley:
