November 26, 2024, 03:20:38 pm
All Things Mk5
Technical Workshop
check brake pads now warning light
Topic: check brake pads now warning light (Read 4290 times)
Jack1992
Taking part
-Given: 1
-Receive: 1
July 07, 2014, 08:23:31 pm »
hi all,
i have recently had a light come up on my dash saying check brake pads now i have looked round the brakes and they all seem good with around 6mm on them could there be a sensor or something that could be playing up?
thanks
jack
bacillus
Just look at my post count
-Given: 4
-Receive: 451
Re: check brake pads now warning light
Reply #1 on:
July 07, 2014, 08:34:19 pm »
Could be a fault with the wiring but IMO jack up the car and check the thickness of left inner pad to make sure the fault is false. The sensor wire is connected to only that pad.
Jack1992
Taking part
-Given: 1
-Receive: 1
Reply #2 on:
July 07, 2014, 08:46:36 pm »
is there a sensor wire to each brake pad? or do they only go to one wheel?
MizGTi
Always Involved
-Given: 0
-Receive: 1
Re:
Reply #3 on:
July 08, 2014, 02:08:56 am »
The front sensor is only on the passenger side. Not sure about rears. But imagine one sensor at the front, one on the rear.
bacillus
-Given: 4
-Receive: 451
Reply #4 on:
July 08, 2014, 07:46:09 am »
Only one sensor at the front left and none at rear.
Jack1992
Taking part
-Given: 1
-Receive: 1
Reply #5 on:
July 13, 2014, 06:11:55 pm »
Does anyone know if I can replace this sensor?
Shaw
Always Involved
-Given: 0
-Receive: 5
Reply #6 on:
July 13, 2014, 07:00:46 pm »
The sensor is part of the brake pad. It works by touching the disc when the pads wear low and completing a circuit (using the disc as ground) which illuminates the warning light.
Either your brake pads are low of the wire that connects to the sensor is damaged and grounding out on the body somewhere. Disconnect the sensors one at a time to diagnose the faulty one. Be sure your inner pads aren't low though.
'07 Mk5 GTI Manual
All Things Mk5
Technical Workshop
