Author Topic: Squealing 3.2 V6 - Any ideas?  (Read 2003 times)
Offline john87
  • -Receive: 53
« on: July 08, 2014, 07:15:13 pm »
After finally getting my Haldex/Final drive unit replaced under warranty, my humble Golf decides to throw yet another odd noise at me  :fighting:
Does anyone have a clue what this could be? It happens when the engine's idling (once fully warmed up) and seems to be coming from the aux. belt area. I'm thinking bearings in the idler pulley or one of the other pullies in that region?
https://www.youtube.com/watch?v=xgR50V8RuDg
« Last Edit: July 08, 2014, 07:53:48 pm by john87 »
Offline RoMocop
Re: Squealing 3.2 V6 - Any ideas?
« Reply #1 on: July 08, 2014, 08:31:14 pm »
You could have a look at this link. i think this could help you. :happy2:
http://www.mk5golfgti.co.uk/forum/index.php?topic=25707.0
Offline john87
  • -Receive: 53
« Reply #2 on: July 18, 2014, 12:19:07 pm »
I've done a bit of 'probing' under the bonnet with a listening stick, and it would seem that the aux. belt tensioner has a nackered bearing.. booked her back into VW to see if it will be covered by the extended warranty  :happy2:
Offline john87
  • -Receive: 53
« Reply #3 on: July 24, 2014, 09:55:37 am »
*Update*
Car went into VW dealer on Monday and was diagnosed with a failing water pump bearing... replaced under warranty, problem solved!  :happy2:
Redemption
« Reply #4 on: July 24, 2014, 08:07:12 pm »
Out of curiosity. Did the noise disappear when you revved the engine and then slowly come back after idling for a while?
Offline john87
  • -Receive: 53
« Reply #5 on: July 24, 2014, 11:05:27 pm »
Yes! This is exactly what used to happen.. also, it only did it when warmed up/driven for more than 10 minutes.
Redemption
« Reply #6 on: July 25, 2014, 07:29:43 am »
My R32 started making this noise yesterday. Another thing to add to the list.
Offline john87
  • -Receive: 53
« Reply #7 on: July 25, 2014, 10:01:14 am »
Just so you know, mines is a 2009/58 plate with just over 54k. The guy at the service desk said he thought it wasn't terribly low mileage for a water pump to fail, modern cars for you eh  :indifferent:
Redemption
« Reply #8 on: July 25, 2014, 02:28:59 pm »
Mine's a 2007 with 71000 miles. Seems to be the mileage where things are starting to fail/break.
« Last Edit: July 25, 2014, 09:43:23 pm by Redemption »
