Author Topic: Ideal time to change gear to save fuels on weekdays :p  (Read 1503 times)
Offline mrggg
  • -Given: 36
« on: July 09, 2014, 04:42:43 pm »
Hi when driving on weekdays petrol costs can be expensive  :P So I was just wondering what is the ideal rpm to change gear and save fuel. I have noticed changing at low rpm the gearbox does feel a bit crunchy, I think it may be that Im not changing gear correctly tho... :indifferent:
thanks.
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
Re: Ideal time to change gear to save fuels on weekdays :p
« Reply #1 on: July 09, 2014, 05:01:00 pm »
Depends on the road. Its not as simple as just the rpm.
dansmith180
« Reply #2 on: July 09, 2014, 06:42:22 pm »
I find my car seems to be most efficient and smooth between 1600rpm and 2300rpm, so assuming flat ground I would change around 2500rpm or less
Offline Danbear79
« Reply #3 on: July 09, 2014, 07:38:38 pm »
While I'm pottering around at weekends, I can get 33-34mpg just from being gentle on the throttle and not reving the tits off it. I find that going into a higher gear too early can cause less mpg because the engine is kind of labouring more.
Offline Spankiee
  • -Receive: 20
« Reply #4 on: July 09, 2014, 07:44:31 pm »
i usually change just before the turbo starts to spool up and ITG intake starts to suck up small animals
seems to work ok
candy white edition 30
Offline homesqueeze
  • -Given: 32
  • -Receive: 43
  • Got another Golf!
« Reply #5 on: July 09, 2014, 07:59:46 pm »
Changing up by 2,000 rpm is supposed to be good for fuel effiency. Seems to work ok for me.
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« Reply #6 on: July 09, 2014, 08:16:59 pm »
It's definitely not all about the gear but the amount of throttle; use a light throttle and anticipate traffic.......all pretty boring really. :evilgrin:
Offline Vwgticrazy
  • -Given: 41
« Reply #7 on: July 10, 2014, 12:26:43 pm »
Think you need a diesel
  • -Receive: 291
« Reply #8 on: July 10, 2014, 12:28:51 pm »
Or buy a small car for the weekend, like an i10.
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=3e4r3meq8hu61a4rgopq8g5gaj&/topic,19740.0.html
« Reply #9 on: July 10, 2014, 12:31:08 pm »
This ^^^
Have the car on 'instant MPG' on the computer and keep and eye on that. Its more about gentle throttle, keeping the boost to a minimal.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #10 on: July 10, 2014, 12:40:51 pm »
This ^^^
Rich has nailed it there.
Feathering the throttle and keeping the revs low as poss without labouring the engine.
planning ahead and coasting down to junctions (with the car still in gear) saves the most fuel so anticipate corners and hills and either ease off to save braking or gently accelerate to gain speed ready for an up hill.
The less you have to use your brakes, the better your doing  :happy2:
« Last Edit: July 10, 2014, 12:42:45 pm by GrayMK5GTI »
