Author Topic: Suspension Top Mounts  (Read 4566 times)
Offline th3_f15t
  • -Receive: 183
« on: July 09, 2014, 05:38:14 pm »
So after some digging about and research + advise, I discovered that AmD Tuning are offering Bilstein suspension kits with free fittings (saving about £250ish, apparently). More info here;
http://www.amdtuning.com/news.read.cfm?articleid=5226
So anyway, I'm wondering if it's worth replacing the suspension top mounts (both front and rear) when changing the dampers and springs as a matter of cause (regardless of whether it's replacement OEM items or full coil-overs). If so, are there recommended ones to uses with after market suspension or just some OEM replacements from the normal parts distributors (Febi by Bilstein for example)?
Many thanks!
Offline SurreyED30
Re: Suspension Top Mounts
« Reply #1 on: July 09, 2014, 05:51:26 pm »
Most on here including myself replace with TT/RS3 top mounts mate and there much stiffer than oem gti
Offline th3_f15t
  • -Receive: 183
« Reply #2 on: July 09, 2014, 06:48:09 pm »
Have you got the part numbers to hand for all the bits I'd need? Also, prices I can expect to pay?
Are the TT/RS3 mounts for both front and rear?
« Last Edit: July 09, 2014, 06:58:43 pm by th3_f15t »
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #3 on: July 09, 2014, 06:57:10 pm »
Here you go  :happy2:
TT/RS3 Top Mounts            8J0 412 331
Bearings for Top Mounts   6N0 412 249 C
Bolts                                  N 101 277 07
Offline th3_f15t
  • -Receive: 183
« Reply #4 on: July 09, 2014, 06:59:05 pm »
Cheers mate. Just modified my original question! :P
Offline biffobear
« Reply #5 on: July 09, 2014, 07:01:26 pm »
You may find that when removing old top mounts, the studs the nuts go on to will start turning and you will have to chisel/grind them off
Offline SurreyED30
« Reply #6 on: July 09, 2014, 07:06:03 pm »
My original top mounts spun and had to be grinded off when I first fitted the Coilovers late last year, when I swapped them out for rs3 mounts last month with the new suspension kit they undone easily. Most probally because they were only 6 months old. Rs3/TT mounts are definitely much better than oem gti ones.
I paid about £53 iirc for the whole lot from TPS
Offline th3_f15t
  • -Receive: 183
« Reply #7 on: July 09, 2014, 07:09:17 pm »
Cool, that's a good price, seeing as ECS tuning sell a front mount kit for £100... Might drop a few quid your way and ask if you can pick me up a set from TPS? :happy2:
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #8 on: July 09, 2014, 07:13:01 pm »
No need to do the rear, front only  :booty:
Offline SurreyED30
« Reply #9 on: July 09, 2014, 07:14:09 pm »
Also seen ecs tuning for £100 and thought sh*t that's pricey wonder what tps or europarts charge so I got a mate to order mine through there works trade account, £53 was a good text message to receive when £100 nearly left my wallet :happy2:
*EDITED*
« Last Edit: July 09, 2014, 07:15:50 pm by SurreyED30 »
Offline th3_f15t
  • -Receive: 183
« Reply #10 on: July 09, 2014, 07:14:55 pm »
Ah, fair enough. Might have to swing by the local Audi dealer with those part numbers and see how much they'll rape me.
Offline SurreyED30
« Reply #11 on: July 09, 2014, 07:16:34 pm »
Haven't you got TPS or europarts near you?
Offline th3_f15t
  • -Receive: 183
« Reply #12 on: July 09, 2014, 07:19:39 pm »
I got a Euro Car Parts near, yeah... Will get on the website and search in a bit. I'm being slow and stupid tonight...
Offline th3_f15t
  • -Receive: 183
« Reply #13 on: July 09, 2014, 07:29:11 pm »
Bolts                                  N 101 277 07
Is it;
2 Top Mounts
2 Bearings
6 Bolts
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #14 on: July 09, 2014, 07:42:42 pm »
