Author Topic: Broken N80 pipe where it meets the top of the engine, near PCV thingy.  (Read 878 times)
Offline cooljimy84
    • Personal
Hello All !!
First post, was a memeber of the mk4 fourm under the same name. But sold my Vikki (mk4 gti AGU engine) to a new dubber, and spent what little money i have on a mk5 GTI.
I told the misses it was because it's safer, with moer airbars, ISO fix seats for when we have kids, and that I wouldn't slam it to the ground....
Any way on with the issue. So last night i was checking for boost leaks with my end cap and 5 PSI of pressure. I could here a leak about traced it back to the little black pipe going from the n80 valve, to the head (between the oil cap and the PCV system) if i remove and refit the connection it holds pressure for a bit, but as soon as you touch it it leaks again.
Can i just get a new pipe ? or find another rubber o ring?
any one had this issue on an AXX engine ?
LOVE YOU !!
There is no replacement for displacement....
But a turbo does help....
Offline cooljimy84
    • Personal
So Halfords (is my only local car place near work) has the size above the O ring and the size below.
So i used the size above and used a small (like for fixing glasses small) flat head screw drive to it in to the hole  :wink:
Gave it a few bounces off the rev limiter, tho at a stand still, and it didn't pop out.
Road test on the way home.....  :driver:
Offline Frenzy
  • -Receive: 29
hope it works, bonne chance!  :happy2:
Offline cooljimy84
    • Personal
Feels better, but the air leak noise is still there on boost. Will have to get the compressor out again  :sad:
