Author Topic: Srs tec front wings 25mm wider any one here running them?  (Read 7861 times)
Offline Dj.Duffa
Any had experience with the srs tec front wings?
I'm after pictures etc
Any other options?
I'm running 3sdm 005s 8.5 j et 42 I think and don't want to run spacers as I have a staggered fitment! And I also don't want it to look silly with the wheels hidden under the arch!
« Last Edit: July 10, 2014, 10:41:09 pm by Dj.Duffa »
Offline Dj.Duffa
Re: Srs tec front wings 25mm wider any one here running them?
« Reply #1 on: July 11, 2014, 12:33:18 pm »
Offline xjay1337
  • -Receive: 377
« Reply #2 on: July 11, 2014, 01:46:07 pm »
For that wheel size you don't need fancy extended wings.
Seen them on one car and looks wrong without wider rear arches too.
Offline Dj.Duffa
« Reply #3 on: July 11, 2014, 05:55:22 pm »
This is my issue but I have folded then and flared as much as poss and I'm still rubbing slightly on a turn with an incline!
I did see a mk6 with them at gti and it looked okay but no idea what the offset was!
Offline Dj.Duffa
« Reply #4 on: July 11, 2014, 05:59:12 pm »
Also the wings I'm on about still look standard! You really wouldn't tell until a standard one is sat next to it!
Obviously you would see the wheel sat under arch more..
Also thinking no rust issues!
I just need more pics etc before I decide what to do!
Offline Pikey Motorsports
« Reply #5 on: July 11, 2014, 10:52:02 pm »
They look very good
TSR PERFORMANCE GTX30 520BHP
LITCHFIELD R35 GT-R 660BHP
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #6 on: July 12, 2014, 09:39:52 am »
I chose the Kerscher ones, 30mm wider and the fitment almost OEM, after i tried the Seibo Carbon ones that idn't fit at all.
I would recommend Kerscher
http://www.kerscher-tuning.de/styling/index.php?marke=VW&typ=Golf+5+%281K%29&gruppe=Kotfl%FCgel+%2F+Seitenteile
Over the top mod list ;o)
Offline Dj.Duffa
« Reply #7 on: July 12, 2014, 01:22:10 pm »
I thought they was the same as the srs ones?
Any pics?
  • -Given: 243
  • -Receive: 154
« Reply #8 on: July 12, 2014, 03:16:05 pm »
Any pics?
Pictures are in my build tread :)
« Reply #9 on: July 12, 2014, 09:17:16 pm »
Danish what size wheel and tyre you run with the wings?
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
  • -Given: 243
  • -Receive: 154
« Reply #10 on: July 13, 2014, 08:06:52 pm »
As i have the TT mk 2 hubs and lower control arms which gives app. 22mm wider track each side it's not exactly comparative of a mk 5 gti, but wheels are 8x18" ET 45 TD PR 1.2
I would like to go TD PR 1.2 9x18" ET 45 but they don't make them with an ET higher than 35. I believe they could be there the 9" and then have 255 wide tyres on for traction, but i have found some 8,5x18" that are a possibility, but funds aren't found for that yet  :sad1:
« Last Edit: July 13, 2014, 08:09:15 pm by danishmkvgti »
Offline Dj.Duffa
« Reply #11 on: July 13, 2014, 09:25:36 pm »
If I get them is it going to sort my issue? Been that the car is low it's rubbing on the wing every now and again when on a turn with slight incline...
Offline Dj.Duffa
« Reply #12 on: July 13, 2014, 09:26:34 pm »
Also xjay I see how low yours Is on your sig.. Is it on air?
Offline xjay1337
  • -Receive: 377
« Reply #13 on: July 13, 2014, 09:46:03 pm »
Then something is wrong.  I barely rubbed at all with 18x8.5et44 and that was before I had rolled arches etc. 115/25 tyres. With the arches etc pulled and rolled then 225/40 would be fine dude
Yes mate car is on air.
Offline Dj.Duffa
« Reply #14 on: July 14, 2014, 10:39:19 am »
Don't get me wrong it's only a little a bit... It's a lot better after folding the arches but I couldn't pull them any more with the tool I had!.
And I have to be on a turn in that's also an incline so like pulling into a drive or something! Doesn't run the arch at all when driving normally
