Author Topic: Woosh sound while accelerating Mk5 GTI  (Read 2837 times)
Offline Bennz
« on: July 15, 2014, 05:23:39 am »
Hi all,
Just want to ensure I'm not confusing this with an issue or the normal sound.
I noticed a woosh sound when I press the accelerator while driving ( sound is audible when window is down ) . It comes when accelerating fast and can't be heard when engine is not under pressure. It stops when accelerator pedal is released.
Is this the normal turbo spooling or faulty DV ?
Offline Bennz
Re: Woosh sound while accelerating Mk5 GTI
« Reply #1 on: July 17, 2014, 12:35:31 am »
Does the turbo in these cars make sound as well or it is relatively quite ? Will check the DV shortly
Offline aarondsg
« Reply #2 on: July 17, 2014, 06:10:43 am »
Is your car remapped?
R-Tech Power Stage 2+ Edition 30 (LC9Z)
Offline Bennz
« Reply #3 on: July 17, 2014, 07:13:45 am »
No it's stock with DSG gearbox
Offline cobz
  • 07 GTI DSG - Stage 1
« Reply #4 on: July 17, 2014, 11:38:26 am »
Mine is stage 1 DSG with rev G DV which was done not too long ago. I get the same woosh
Offline Twiggy
« Reply #5 on: July 17, 2014, 01:38:22 pm »
check your DV, will prob have split. any loss of performance?
2005 mk5 R-tech custom stage 1
Offline Dj.Duffa
« Reply #6 on: July 17, 2014, 02:05:17 pm »
Has it got a induction kit fitted?
Offline howie1987
  • -Given: 92
  • -Receive: 20
Re:
« Reply #7 on: July 17, 2014, 05:18:52 pm »
Mine does a woosh sound but it has an induction kit on it.
Offline Bennz
« Reply #8 on: July 17, 2014, 09:38:22 pm »
The car is fully stock . I don't think I have performance loss but unfortunately I don't have access to another mk5 GTI to confirm .
Does the turbo in these engines makes audible spooling up sound ?
Offline martin@gti.co.uk
« Reply #9 on: July 17, 2014, 09:58:36 pm »
Get live logging with vcds under load.. but most likely nothing...if the performance isnt affected. Any overboost/underboost would cause limp mode anyway..visual inspection or remove dv valve quick check..
Offline Bennz
« Reply #10 on: July 18, 2014, 04:47:53 am »
Thanks all . Don't have VCDS but going to check the DV soon
Offline julian_ramos
« Reply #11 on: July 19, 2014, 06:08:41 pm »
Thus happened to me and it was the dv loosing boost, I changed it for a metal piston style one from awsome gti and it made all the difference
Offline Twiggy
« Reply #12 on: July 21, 2014, 11:26:23 am »
Rev. G Diverter Valve --- 06H 145 710 G
 :drinking:
