Author Topic: abs light  (Read 641 times)
Offline slider955i
  • you are only here once so enjoy
abs light
« on: July 17, 2014, 06:45:11 pm »
abs light just came on as i was driving home grrrrrr
gt sport 170 tdi , p - torque stage 1 map 208 bhp 338 ft lb
powder coated gunmetal alloys and caliper colour change
Offline slider955i
Re: abs light
« Reply #1 on: July 17, 2014, 06:47:41 pm »
fitted new discs and pads a month ago wander if brake dust on sensor
Offline martin@gti.co.uk
Re: abs light
« Reply #2 on: July 17, 2014, 09:36:14 pm »
Diag.?  :driver:
Offline slider955i
Re: abs light
« Reply #3 on: July 18, 2014, 09:20:37 am »
drove it this morning and has i pulled away light went off , may be a blip or something impending lol we will see
my mate has full diagnostic equipment so will get it checked out
Offline slider955i
Re: abs light
« Reply #4 on: August 03, 2014, 11:26:38 pm »
left rear sensor intermittent fault , new one ordered  , diagnostic great my mate got latest vag setup
Offline DDM
Re: abs light
« Reply #5 on: August 03, 2014, 11:41:52 pm »
Had a similar prob with mine just a week ago, but I had 3 lights on the dash, one abs, one tps, and the other was the skid light that I think stands for esp, when I read for faults it came up with right rear abs sensor failure, but the problem was a crack in the abs ring on the back of the wheel bearing hub. You can actually see these between the caliper and backing plate to check before removal.
Offline gtgeorge
Re: abs light
« Reply #6 on: August 04, 2014, 01:29:49 am »
mines on, because i ripped the plug out changing coilovers  :signLOL:
Offline slider955i
Re: abs light
« Reply #7 on: August 04, 2014, 07:41:34 am »
was the abs ring expensive , thanks
