Author Topic: Advice re maintenance.  (Read 1398 times)
Offline bbfb10
« on: July 17, 2014, 09:10:49 pm »
Right, lm on a limited budget and can only afford to do these one at a time, my question is what order should l do them in?
DV (Rev G, obviously)
PCV
Cam Follower.
I figure Cam follower is best to do first, followed by PCV, then the DV. Is this right? If anyone has any advice or opinions Id welcome the input.
Ta.
Ben.
Full VCDS Hex + Can.
Offline Markyed30
Re: Advice re maintenance.
« Reply #1 on: July 17, 2014, 09:13:43 pm »
Id do the cam follower and plod away if everything is ok tbh if ur PCV and dv is holding up and I was limited fund wise I'd leave it be
Offline martin@gti.co.uk
« Reply #2 on: July 17, 2014, 09:40:41 pm »
Are you a new owner? First I would do a cam belt oil plugs etc.., regardles of what they say.. but makes sense start from cam follower for piece of mind, most likely still minted. Pop the pump off and check it get new O ring seal as well. All above would leave a fault code at engine ecu..what eng code is yours?
dansmith180
« Reply #3 on: July 17, 2014, 10:32:45 pm »
Out of those 3 it's got to be cam follower.
Offline betty_swollox
  • -Receive: 29
« Reply #4 on: July 17, 2014, 11:34:34 pm »
defo
2010 Leon CUPRA
BCS Powervalve Exhaust
Revo Ceramic Intake
APR Stage 2
Offline chowgar
« Reply #5 on: July 17, 2014, 11:44:28 pm »
whats your milage... stock or mapped?
Offline Shoy1980
Re:
« Reply #6 on: July 25, 2014, 12:09:45 pm »
Got this quote from AMD Tuning, does it sound about right?
PCV Valve - £32 + vat
DV – £52 + vat
Cam Follower - £26 + vat
Labour - £90  + vat
Offline dan930
  • -Receive: 56
« Reply #7 on: July 25, 2014, 02:20:00 pm »
defo
+3...check the cam follower...
MK6 golfR dsg
AKS TUNED
NORTECH PERFORMANCE HTA3071
R TECH custom map
