Author Topic: Help! Golf not wanting to start!  (Read 5163 times)
Offline davep84gti
« on: July 18, 2014, 02:06:06 pm »
Hi all, anyone have any idea's as to whats wrong with my gti??
So heres what happens....
I go to start the car as normal.... the engine turns as it should and the engine starts, seconds later it cuts out with no warning lights or anything. Try to restart it then the engine turns over but doesn't start!
If you leave it for 10 minutes or so with the ignition on it 9 times out of 10 starts up as normal and is absolutely fine for weeks and then happens all over again!
Re: Help! Golf not wanting to start!
« Reply #1 on: July 18, 2014, 02:24:43 pm »
Immobiliser issue??
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #2 on: July 18, 2014, 03:32:14 pm »
what is your location?
get a scan done
Cluster and Key coding
Location Great Yarmouth
Offline davep84gti
« Reply #3 on: July 18, 2014, 06:46:16 pm »
went down to a friends garage and stuck it on the vag com, looks like its a new fuel pump for the gti :/ which pump out of the two which is knackered is beyond me
« Reply #4 on: July 18, 2014, 07:57:33 pm »
My guess it's your in-tank lpfp...
Offline doylebros
« Reply #5 on: July 18, 2014, 09:30:11 pm »
As above or the fuel filter has never been changed would be my first thoughts.
Offline Vwgticrazy
  • -Given: 41
« Reply #6 on: July 19, 2014, 12:28:36 am »
Friend had this happen on his 06 golf it was the battery
Offline davep84gti
« Reply #7 on: July 19, 2014, 05:19:00 pm »
having a new tank pump fitted first.. just tried starting it and its not having any of it and keeps cutting out seconds after starting.
Offline doylebros
« Reply #8 on: July 19, 2014, 05:26:46 pm »
Open and close the drivers door a few times and listen for the pump priming the system - remember the fuel filter on the GTI is not a service change item so could be the original!
Offline davep84gti
« Reply #9 on: July 20, 2014, 04:30:41 pm »
tried starting it earlier and it was absolutely fine
Offline davep84gti
« Reply #10 on: July 21, 2014, 09:57:33 am »
so if i hear no priming then its the tank pump??
Offline martin@gti.co.uk
« Reply #11 on: July 21, 2014, 01:53:57 pm »
There is a fuse as well for a fuel pump..
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #12 on: July 21, 2014, 02:48:35 pm »
Check the fuse for the LP Fuel pump
Also check the wiring to the LPFP
Offline davep84gti
« Reply #13 on: August 03, 2014, 08:18:19 pm »
had a new tank pump fitted last wednesday and all seemed well till 10 minutes ago and now its doing the same thing again!!!
« Reply #14 on: August 03, 2014, 09:09:15 pm »
Is the lpfp priming, you should hear a noise if you open the driver's door.
I would also change your fuel filter if you haven't already done so.
