Author Topic: Help! Golf not wanting to start!  (Read 5161 times)
Offline davep84gti
Re: Help! Golf not wanting to start!
« Reply #15 on: August 05, 2014, 04:59:17 pm »
could it be low pressure fuel pump sensor sender???
Offline martin@gti.co.uk
« Reply #16 on: August 07, 2014, 10:38:37 am »
Have you tried to replace low pressure thrust sensor yet vw part #06E906051J, but also might need hpfp replaced too..   Im taking you checked the 20 amp fuse for lpfp and wiring..hope you get it sorted mate..
Offline davep84gti
« Reply #17 on: August 07, 2014, 10:55:07 am »
having a new sensor fitted today, and I've ordered a new cam follower aswell. I really hope this sorts it out as its nearly time for Trax and can't be having a dodgy car driving up there from plymouth lol
Offline davep84gti
« Reply #18 on: August 11, 2014, 09:19:29 pm »
well..... its not the sensor :(
dont know wether its me or not but I'm sure every time it happens the Lightbulb out light is on.. and i also noticed this time the ESP light on the switch was illuminated... I'm now thinking I've got a wiring problem! :/
« Reply #19 on: August 11, 2014, 11:04:01 pm »
Time to get another scan me thinks...
Offline davep84gti
« Reply #20 on: August 11, 2014, 11:09:30 pm »
had it scanned... all that came up this time was a fault with the cd changer and abs fault
Offline davep84gti
« Reply #21 on: August 14, 2014, 09:35:51 pm »
some ones just said to me it sounds like the valves burnt out due to excessive carbon build up...
could it be carbon build up??
My local garage has a Terraclean machine which removes all this carbon stuff.. worth a try?
Offline davep84gti
« Reply #22 on: August 23, 2014, 08:01:06 pm »
Well well well......... seemed to of fixed the problem.. replaced a light bulb that kept flicking on and off all the time and then unplugged the battery for a hour or so. 12 days on and hasn't cut out once!! :) :happy2: :laugh: :driver:
