Author Topic: Part Number request - Interior grab handle plastics  (Read 1310 times)
Offline OLLIE_JETTA_MK5
« on: July 19, 2014, 04:50:40 pm »
Hello :)
Has anyone got the part numbers for drivers and passenger door handles, the rubber coating etc is all scratched and i have fresh switches to put in
also the DSG panel trim number around the gaitor
Cheers in advance
Dubbin it since 2006
Offline CarlW
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,92229.msg927100.html#msg927100
Re: Part Number request - Interior grab handle plastics
« Reply #1 on: July 19, 2014, 05:10:14 pm »
For a 3dr?
Part number for drivers side - 1K3 868 050 C 75R
Part number for passenger side - 1K0868039A
May want to check these to make sure they're for UK 3dr cars but I'm sure they are :happy2:
« Last Edit: July 19, 2014, 05:41:42 pm by CarlW »
Offline CarlW
« Reply #3 on: July 19, 2014, 05:46:04 pm »
This might help on the door handle part
http://www.partscats.info/volkswagen/en/?i=cat_vag_models&brand=vw&number=1714&set=1728&ein=2007&f=474&hauptgr=1234567890&hg=8&grf=086705420&bf=86705&hgug=867&ug=67&parent_id=2353803
Not sure what you mean on the DSG item?
This might help
http://www.partscats.info/volkswagen/en/?i=cat_vag_models&brand=vw&number=1714&set=1728&ein=2007&f=474&hauptgr=1234567890&hg=7&grf=071310409&bf=71310&hgug=713&ug=13&parent_id=2348234
Are these part numbers for the 4 door though? If so they will have different part numbers to the 3 door versions as 3 door's don't have provisions for the electric buttons for rear windows
Offline doylebros
« Reply #4 on: July 19, 2014, 05:50:13 pm »
This might help
When you open the link it says in the note section which vehicle there for!
Offline reaper7881
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,68492
« Reply #5 on: July 19, 2014, 07:42:42 pm »
hi mate i think i have what your looking for. ill take a pic of it in a sec
is that it
if so then here's the part number 1k3 868 050 c
« Last Edit: July 19, 2014, 07:53:48 pm by reaper7881 »
54 MK5 Golf 1.9tdi 3dr SMD Full Interior and Speedo Conversion, GTi Highline , Flat Bottom Wheel, ED30 Rear lights
« Reply #6 on: July 20, 2014, 01:04:58 am »
Cheers lads :)
