Author Topic: Door lock module problem  (Read 1116 times)
Offline Paultc90
« on: July 21, 2014, 01:00:24 pm »
I've just replaced my door lock module on my passanger side rear door. It wouldn't seem to lock.
The new unit seems to be doing the same thing though!
You can lock the module by hand and will work and when you use the unlock button in the keys it opens as normal. But won't lock as normal when pressing the lock button.
Any ideas?
Offline martin@gti.co.uk
Re: Door lock module problem
« Reply #1 on: July 21, 2014, 02:31:08 pm »
Vcds scan central convinience module for faults..
Offline doylebros
« Reply #2 on: July 21, 2014, 07:49:41 pm »
As above advises that would of been my starting point. However, was the item you fitted new or used as these items are very problematic?
