Author Topic: RH drive shaft rubbing chassis very slightly.. any one else? & solution  (Read 556 times)
Offline Dj.Duffa
as avove.. noticed yesterday.. must be minimal.. any one else had it? and what did you do?
chassis notch seems to be a bit of a grey area and its naff all I really think chassis notch would be overkill..
Offline jaffa
  • -Receive: 44
either get a notch or let it rub its own notch
Offline Dj.Duffa
 :signLOL: what n then just give it a lick of paint..
Offline jaffa
  • -Receive: 44
Pretty much yeah
Offline Dj.Duffa
Brilliant  :signLOL:
Might also stick One of those apex clip on bump stops in each side of the coil overs as well see if that helps..
Offline flashp
  • -Receive: 65
Noticing your earlier post re car parks,  is it fair to assume that this is somehow caused by lowering?
Clearly the changes made have altered the proximity of other parts to the drive shafts. It'd be worth getting to understand what's changed and how then I think you'll have your answer.
Gone but not forgotten :-)
Offline Dj.Duffa
Well it's on coilovers and it's low, that's what's changed lol
« Last Edit: July 23, 2014, 11:56:14 pm by Dj.Duffa »
