Author Topic: VWR Intake Install - Progress slows  (Read 11260 times)
Offline bluo
Re: VWR Intake Install - Progress slows
« Reply #30 on: October 27, 2018, 11:54:49 pm »
@bluo i think i might have done something similar to mine when fitting - currently have coolant leaking all over the place.
what was the part called that you ordered from the main dealer?
thanks
Not sure what the part was called, I just removed it and took it to the dealer and got another two days later.
Offline bluo
« Reply #31 on: October 27, 2018, 11:55:11 pm »
Bump - anyone know how to prevent this? Just had it fixed but the mechanic said it will happen again as it's putting pressure on it
Remove the intake and buy a decent one!
Offline Lewo
« Reply #32 on: October 28, 2018, 02:52:10 pm »
I've seen some UK made ali hose connectors on some of the Facebook groups cheaper than the one Dave J linked to.
« Reply #33 on: October 30, 2018, 04:28:01 pm »
The clearance for the coolant elbow is entirely dependant on how the air guide is fitted to the slam panel.  It needs a bit of experimenting (and raising the canister height as discussed) to find the right compromise.  You shouldn't have to do that on a well designed product, but [sh]it is what it is unfortunately.
