Author Topic: Bonnet won't close help!!!!!  (Read 2779 times)
Offline golfgti10
« on: July 23, 2014, 06:38:22 pm »
Just opened my bonnet now it won't go down, can any one help asap
Offline biffobear
Re: Bonnet won't close help!!!!!
« Reply #1 on: July 23, 2014, 06:53:55 pm »
Make sure nobody is still working under the bonnet :signLOL: , seriously do you mean it won't go back down from the raised position?
Offline golfgti10
« Reply #2 on: July 23, 2014, 07:01:13 pm »
It's the mechanism I think won't close as the catch don't catch
Offline jaffa
  • -Receive: 44
« Reply #3 on: July 23, 2014, 08:07:14 pm »
Grease the catch and wiggle the catch around with a flathead screwdriver.
You can keep greasing it but its best to replace it as it will keep seizing
New catch is around £30 from the dealers
Offline RifGTi
« Reply #4 on: July 23, 2014, 09:55:46 pm »
Ive had this problem and it drove me nuts when i came across it.
For me the problem was the lever in the drivers cabin. I had to wiggle it a little bit before the bonnet would catch. Altought saying that my wife helped me find the issue the first time it happened.
Sometimes the bonnet will close by itself other times it doesnt like it until i fiddle with the lever
Hope it helps
Offline Chris92
  • -Given: 33
« Reply #5 on: July 23, 2014, 10:51:02 pm »
Mine used to shut fine then other times it wouldn't so I sprayed it with wd40 then sprayed white grease on the latch part thing and I've had no problems since.
Offline callis
« Reply #6 on: July 24, 2014, 05:11:01 pm »
I changed the bonnet catch on the wife's tdi, same as gti, and did a how too on this forum
http://www.mk5golfgti.co.uk/forum/index.php/topic,55146.msg622816.html#msg622816
05 GTI 5 Door, sunroof, met paint, 18" monza, Leather Anthacite, front centre armrest, xenon headlights, Lux pack 2, Sensors, Winter Pack.
Offline Mev
« Reply #7 on: July 24, 2014, 08:40:50 pm »
I had this too, had to ensure that  cabin release lever was back in position.
