Author Topic: Highline Clocks Upgrade - NEED HELP  (Read 4913 times)
Offline Georrge
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,93533.msg937034.html#msg937034
« on: July 23, 2014, 07:15:26 pm »
Hi guys,
I've come across some highline clocks for £80, they are out of a 2007 vehicle. My car is a 2005 mk5 golf gti.
I came across this guide when searching up on how to switch over from midline: http://www.golfgtiforum.co.uk/index.php?topic=201776.0
Following that guide, doing the coding as showed, will the clocks work in my car?
Looking at that guide it seems like a relatively process, but I've also read that it can be a nightmare to code and you need a special type of vag com cable to code it?!
Any help will be greatly appreciated.
Thanks a lot!
Instagram @george_kersh
Offline Nodz
  • -Given: 73
  • -Receive: 103
Re: Highline Clocks Upgrade - NEED HELP
« Reply #1 on: July 23, 2014, 07:54:35 pm »
What part number does the clocks have on your current ones and what mum ever does the new one have?
Some you can swap and other you need a different piece of software for the immo data etc which eddie-NL and kali can do
Offline Georrge
« Reply #2 on: July 28, 2014, 10:05:46 am »
I will have to check my current ones, the seller isn't replying to me now so can't get hold of the part number..
So are you saying that some are more straight forward than others, but they will all work with any model, just may need a bit more done to them which eddie can sort out?
Thanks a lot buddy :happy2:
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #3 on: July 28, 2014, 10:16:32 am »
As long as its a 970, 971 or 972 ending part number, following the guide will work. I used the same guide when I did mine the first time and was a great help.
Offline Georrge
« Reply #4 on: July 30, 2014, 08:07:27 am »
Thanks a lot! I'll pester the seller some more, it confuses me when someone wants to sell something but is then poor at replying to any interest given haha  :signLOL:
Offline skard
  • -Receive: 245
« Reply #5 on: July 30, 2014, 09:13:01 am »
Coming out of an 07 they'll be at least x73 or maybe x74 clocks so you will need a genuine Commander cable to program the highline cluster.
Offline Georrge
« Reply #6 on: July 31, 2014, 07:46:29 pm »
Ok thanks a lot, the seller isn't replying so I'll post a wanted add on here and make sure to get a set ending in 970, 971 or 972.
Cheers for your help! :happy2:
Offline skard
  • -Receive: 245
« Reply #7 on: August 01, 2014, 08:53:01 am »
Have you got a multi function steering wheel? If so post up the pics of the buttons as they differ.
Older style you want x70/71, newer style x72/73/74.
If no MFSW I'd still only go for x72 or newer
Offline Georrge
« Reply #8 on: August 01, 2014, 09:56:26 am »
I don't have a MFSW unfortunately. Why would you only go for 972 and not 970 or 971?
Offline skard
  • -Receive: 245
« Reply #9 on: August 01, 2014, 10:12:08 am »
They rely on different buttons & the use of the MFA stalk.
If you ever planned for MFSW then aim for the newer versions, in my opinion.
Offline Georrge
« Reply #10 on: August 01, 2014, 03:21:51 pm »
Ah I see. If I ever bothered to upgrade, it would be to a mk6 MFSW, but I doubt I will as it's a really pricey upgrade! Will the old ones still work with the MFSW if I did ever upgrade?
I've found a new seller for the clocks, and the part number is: 1K6920 972D
If for some reason I mess up and can't get them working, will my current clocks be plug and play to get working again? Hopefully it will be nice and straight forward though  :signLOL:
Thanks so much for all your help so far!
Offline skard
  • -Receive: 245
« Reply #11 on: August 01, 2014, 09:44:37 pm »
972 clocks are ideal, your current ones can go back in assuming you keep the same keys (they're linked up).
Offline Georrge
« Reply #12 on: August 01, 2014, 09:53:03 pm »
Thanks so much! He's asked for £150 but will try and get him down to the £100 mark, how much do they normally go for?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re:
« Reply #13 on: August 01, 2014, 09:59:16 pm »
972s normally go between 100 and 150 because they are easier to program.  Cheapest I found 971 clocks was 40quid once.  Didnt think the seller knew what they were worth.
You can plug your old clocks back in and should work ad long as you don't overwrite it with another immobiliser data.
Offline Georrge
Re:
« Reply #14 on: August 01, 2014, 10:02:58 pm »
Awesome thanks a lot! He's just got back to me with £120, looks like I've got myself a nice little upgrade. Hopefully he can fit them for me too for a little extra  :happy2:
