Author Topic: Highline Clocks Upgrade - NEED HELP  (Read 4901 times)
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re:
« Reply #15 on: August 01, 2014, 11:32:03 pm »
You can always spend 12 quid on the cable and diy :)  but then you would need vcds to reset any errors that may come up.
I remember the first time I did it I wrote down the vcds way of doing the clock change too but the vag commander way is so much easier.
Offline usmangti
Re: Highline Clocks Upgrade - NEED HELP
« Reply #16 on: August 02, 2014, 12:43:07 am »
They rely on different buttons & the use of the MFA stalk.
If you ever planned for MFSW then aim for the newer versions, in my opinion.
I swopped a 960 for a 972 speedo with the newer MFSW buttons and the MFD works on both my stalk and the MFSW. However can only access menu using MFSW
Offline Georrge
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,93533.msg937034.html#msg937034
« Reply #17 on: August 02, 2014, 12:59:24 am »
Look what I just picked up (yes, at midnight :signLOL:)
Got them for £110, one broken clip but other than that all looks well. Will get them fitted this week before my car has it's service :laugh:
Instagram @george_kersh
Offline usmangti
« Reply #18 on: August 02, 2014, 01:03:33 am »
Will look great mate defo get MFSW with newer buttons there's a few toys that way.
Offline skard
  • -Receive: 245
« Reply #19 on: August 02, 2014, 09:24:10 am »
Newer clocks with newer MFSW layout (like you have) is what I was suggesting
Offline Georrge
« Reply #20 on: August 03, 2014, 04:18:41 pm »
This may seem like a stupid question, but how can I prove that the mileage I set the new clocks to is the genuine mileage down to the exact mile?
Offline skard
  • -Receive: 245
« Reply #21 on: August 03, 2014, 04:46:04 pm »
Take pictures with the old and new clocks showing same mileage. You'll likely input them in kilometres which is even more accurate.
It can always be up for dispute but checking MOT's for mileage can sort of back you up to the mileage at the previous tests.
Offline Georrge
« Reply #22 on: August 03, 2014, 09:08:55 pm »
Ok I will do, my car is in for a service this week too so I'll wait for after the service to put them in, then thats my log book stamped!
Offline Georrge
« Reply #23 on: August 19, 2014, 10:12:56 pm »
Got them fitted and coded today, all working!  :laugh:
However, I didn't realise I wouldn't be able to access the main menu without the MFSW.. oops  :signLOL:
