Author Topic: Battery drain issue  (Read 928 times)
Offline Fozzie
Battery drain issue
« on: July 24, 2014, 05:18:40 pm »
Fitted my RNS510 version P with a new can gateway version S last week and everything was working fine but didn't use the car over the weekend and on Monday the battery was completely flat so we jumped it and it was fine. Been fine since Monday but went to use it today and it's completely flat again do you think this is related to the can bus, unit or the firmware?
Any help or advice would be great as I thought everything should be working 100% without any battery drain.
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
Re: Battery drain issue
« Reply #1 on: July 24, 2014, 09:25:38 pm »
Have you done a VCDS scan in case it isn't coded correctly?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #2 on: July 25, 2014, 09:34:54 am »
post a full autoscan up
The gateway should be ok
what firmware is on the unit?
Cluster and Key coding
Location Great Yarmouth
Offline Fozzie
« Reply #3 on: July 25, 2014, 03:37:20 pm »
So am I right in thinking my firmware version is 5238?
My can gate way is 7N0907530S
Any ideas why I am still getting battery drain?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #4 on: July 25, 2014, 06:22:19 pm »
post up a full scan
