Author Topic: Rcd510 help  (Read 2157 times)
Offline Mickmk4
Rcd510 help
« on: July 27, 2014, 12:45:54 pm »
I'm thinking about buying an rcd510 and been reading about the battery drain issue. How can I find out if I need to change the gateway or not? Any help will be appreciated
Mike
Offline Mickmk4
Re: Rcd510 help
« Reply #1 on: July 27, 2014, 12:47:39 pm »
I forgot to mention it's a jan '07 edition 30 with a highline computer and MFSW  :happy2: (if that helps at all)
Offline Carpy25
Re: Rcd510 help
« Reply #2 on: July 27, 2014, 03:05:00 pm »
From what I've read you should be OK with 2007  :happy2:
Rob
Offline simonp
  • -Receive: 38
  • No longer a Golfer
Re: Rcd510 help
« Reply #3 on: July 27, 2014, 03:34:57 pm »
Borderline OK anyway. Somewhere in 2007 is when they changed to the K revision gateway, which is the one required, I believe.
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
Re: Rcd510 help
« Reply #4 on: July 27, 2014, 04:06:03 pm »
I've just fitted a 3rd generation tp my 57 ed30 no issues at all
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline Mickmk4
Re: Rcd510 help
« Reply #5 on: July 27, 2014, 04:33:58 pm »
Would there be anyway I could check what revision my gateway is? It has the later style buttons on the steering wheel from what I've seen also, that could mean they also changed the gateway which would be nice.
Offline Viking
  • -Given: 17
  • -Receive: 47
Re: Rcd510 help
« Reply #6 on: July 27, 2014, 05:30:22 pm »
A diagnostics scan with VCDS will tell you what revision your gateway is.
Sarcasm for free. Anything after that can only be considered as a bonus.
Just because you think you know something, doesn't make you an expert if you've just read it on the internet, y'know.
Offline DamoP
  • -Receive: 115
Re: Rcd510 help
« Reply #7 on: July 27, 2014, 06:11:26 pm »
if you have small hands a large patience then its generally above the pedals. i have neither  :signLOL:
Offline sootpig
Re: Rcd510 help
« Reply #8 on: July 27, 2014, 06:54:05 pm »
I have revision K from March 07  No drain when fitting RCD510 DAB  As said vcds scan will reveal your gateway revision
Offline J400uk
  • -Receive: 27
Re: Rcd510 help
« Reply #9 on: July 27, 2014, 07:26:57 pm »
Yeah you're very much on the borderline of whether or not it will support it. As above there is no way of telling other than either removing the gateway or doing a VCDS scan. Its only on the 2008MY cars which you can say for sure that it will have a newer gateway.
Offline Mickmk4
Re: Rcd510 help
« Reply #10 on: July 27, 2014, 09:26:01 pm »
Well the only kind of vagcom I have is a cheap ebay cable and that won't read the car so it's now in the bin. I searched for an hour looking for the canbus to get a part number and I could not find it, it's certainly not where it appears to be in the pictures I've seen anyway, I can see a red plug behind a wall of relays but that's about it and to get to that would mean I have to take off half the bottom bit of the steering column at least. Does this sound right? I'm going to ask about and see if there is anybody who would scan it for me and just hope it doesn't need changing.
Offline doylebros
Re: Rcd510 help
« Reply #11 on: July 27, 2014, 09:35:13 pm »
This is the best way for my money to change the gateway
http://www.r32oc.com/topic/29242-canbus-gateway-location-removal/
Other people seem to be more flexible and have fingers with eyes in the end but me!
« Last Edit: July 27, 2014, 09:40:00 pm by doylebros »
Offline Mickmk4
Re: Rcd510 help
« Reply #12 on: July 27, 2014, 09:53:58 pm »
That's a brilliant thread on r32oc. If I can not find anyone with vcds near me then I'll be doing this once the tool for removing the wipers is bought. Appreciate all the help you guys have given me  :happy2: will update once I know what it is just for the people who are curious. And hopefully my post count will will be near ten so I can get in touch with nads about his crud and Bluetooth for sale as he is not to far from me.
Offline Viking
  • -Given: 17
  • -Receive: 47
Re: Rcd510 help
« Reply #13 on: July 27, 2014, 10:00:04 pm »
Just in Richmond if you want a vcds scan.  :happy2:
Offline Mickmk4
Re: Rcd510 help
« Reply #14 on: July 27, 2014, 10:15:42 pm »
Perfect only 20 mins away, could you enable the drl's also?
