Author Topic: Standard pads or aftermarket?  (Read 1309 times)
Offline Stevepd
  • -Given: 49
« on: July 29, 2014, 11:34:38 am »
It's coming to that time where I need to change front & rears. My question is would I be better off get VW pads or go the aftermarket route. I do 330 miles a week, my car is standard. I cannot identify the current fronts pads (or via S/H) but the rears are T1377 pagid pads. Would I be better off spending a few more £'s for longevity? :driver:......
Steve
Standard 5 Door Shadow blue.
Offline john87
  • -Receive: 53
Re: Standard pads or aftermarket?
« Reply #1 on: July 29, 2014, 12:01:29 pm »
A wise mechanic once told me...
Performance parts almost always cost more and don't last as long  :grin:
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #2 on: July 29, 2014, 12:12:14 pm »
If you're not looking for increased performance I'd probably go for OEM equivalent after market ones (such as pagid or textar etc) who may well actually make the OEM pads anyway.
If you want more performance, I'd wait for the wise Dave B to give his input.
PLANS: Stage 2+
Offline Bennz
« Reply #3 on: July 29, 2014, 12:27:36 pm »
What about Vaico semi ceramic pads? Any opinions on those?
Offline th3_f15t
  • -Receive: 183
« Reply #4 on: July 29, 2014, 12:29:06 pm »
A good set of road use Brembo or Fereodo pads will cost about the same as OEM parts and work as well, if not slightly better. I agree that a common misconception is that after market parts are always better than the OEM, but if you're rolling stock, then perhaps save some money and get Pagid parts, they're perfectly fine for normal use and you save cash.
Offline J400uk
  • -Receive: 27
« Reply #5 on: July 29, 2014, 01:07:06 pm »
I'm due a new set and have gone for Mintex ones. Did some reading before they seem to be fairly well recommended and a good price.
Offline 56OctyVRS
  • -Receive: 72
« Reply #6 on: July 29, 2014, 06:07:00 pm »
If the car is std and only used on the road then std ones will be more than fine. They worked well on my octy with 270ish bhp. I got mine from TPS.
Offline ED30 Fish
« Reply #7 on: July 29, 2014, 09:05:12 pm »
Agreed, for standard use - OEM.
If you're into fast road / track then I rate the ferodo ds2500. They maintain efficiency well under high heat and are refined enough for a daily driver.
