Author Topic: NSQBBK Scirocco Interlargos spacer size  (Read 1412 times)
Offline wrlcs
« on: July 29, 2014, 04:23:41 pm »
Hi,
I'm going to add a NSQBBK to my 2009 Scirocco and I am interested to know what size of spacer if any is required to fit the calipers behing Scirocco Interlargos wheels.  I've got the calipers and would assess at least a 5 mm but it would be good to have some proper information.
Thanks,
Brendan
Re: NSQBBK Scirocco Interlargos spacer size
« Reply #1 on: July 29, 2014, 07:43:34 pm »
I have no answer to your question but if a 3mm spacer isn't enough then don't use a 5mm spacer as your likely to be plagued with wheel wobble because those spacers aren't hub centric.
You can get a 8mm and thicker H&R true hubcentric spacer to avoid wheel wobble.
Offline wrlcs
« Reply #2 on: July 30, 2014, 06:56:34 pm »
Thank you for the advice, I will add spacers to the list of parts needed for the NSQBBK.
Regards,
Brendan
Offline th3_f15t
  • -Receive: 183
« Reply #3 on: August 02, 2014, 08:52:03 pm »
Don't forget longer wheel bolts too! :happy2:
