Author Topic: Engine cutting out after fitting intake.  (Read 2475 times)
Offline wilsy_
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,86723.msg952943.html#msg952943
« on: July 30, 2014, 08:58:26 am »
Fitted a Revo to my edition 30, and it's started to cut out.
It only happens when I have the clutch in, which lets the revs dip the whole way to zero.
Any idea how this could be resolved? Im pretty sure every things been put together correctly.
Ryan
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=sd75uq5o8c60051d7i9qge84u7&/topic,19740.0.html
Re: Engine cutting out after fitting intake.
« Reply #1 on: July 30, 2014, 09:08:29 am »
Is the DV return pipe connected up properly?
Offline wilsy_
« Reply #2 on: July 30, 2014, 09:34:55 am »
Yeah MAF is in correctly, and so is the DV pipe.
Spoke to a friend and he thinks the intake has came lose at the turbo end.
Either that or im going to try reset the ECU at lunch.
Offline edition30jmr
  • ED30
« Reply #3 on: July 30, 2014, 11:13:17 am »
Happened with mine it's deffo an air leak at the turbo end! Try and refit and see if it happens again!
Ed30 Beast!
Offline Pikey Motorsports
« Reply #4 on: July 30, 2014, 11:42:37 am »
Strange even if the intake has come loose at the turbo it probaly wont cut out, hasnt on my car anyway, Possibly if its completly not sealed around the turbo atall
TSR PERFORMANCE GTX30 520BHP
LITCHFIELD R35 GT-R 660BHP
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
Offline wilsy_
« Reply #5 on: August 06, 2014, 09:07:46 pm »
So had the car serviced today, intake checked etc and it was perfect. No fault codes came up but still is cutting out.
Mechanic suggested possible throttle body?
Any other ideas.
It's liveable at the moment, as doesn't cut out if you just tap the accelerator when having the clutch in.
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #6 on: August 06, 2014, 10:55:32 pm »
Try another intake dude, or try your old one back on, just to see if its the revo intake at fault  :happy2:
Silver is the way !
Offline martin@gti.co.uk
« Reply #7 on: August 06, 2014, 11:35:27 pm »
Try clutch pedal sensor if its cutting out when pedal depressed. Common fault on vw audi range..
Offline wilsy_
« Reply #8 on: August 07, 2014, 01:45:50 pm »
Going to try this over the weekend and see! If not I have no idea
Offline Carl123
« Reply #9 on: August 09, 2014, 01:03:52 pm »
I have a similar problem mine does not cut out tho just my boost gauge drops slightly for a second :/
Offline audiman
« Reply #10 on: August 13, 2014, 12:19:30 am »
^^^ that's normal. It changes due to the timing changing when foot on the clutch. Proves your pedal switch works!
Mk5 GTi ED30 - 360ps
B7 RS4 supercharged - 650ps
Mk2 GTi 4motion 1.8T - 450ps
Offline Carl123
« Reply #11 on: August 13, 2014, 09:43:52 am »
Ahh cheers pal thought I had a problem somewhere
« Reply #12 on: August 18, 2014, 12:51:20 pm »
I would put the standard airbox on and see what happens
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
