Author Topic: After some advice please.  (Read 1726 times)
Offline ED300888
« on: July 31, 2014, 04:16:49 pm »
I am unsure on 2 planned mods for my ED30 and would like some advise from experience please.
I am definately getting a rear H&R ARB but not sure if to get front done as well. From what I can gather it is pointless/counter productive on FWD but I have been told they actually work well together. Has anyone fitted the rear then added front that can give their experiences on improvement or lack of by doing so?
Also getting R32 front brake upgrade and want to know if the rear is a worth while upgrade as again been told yes and no for them lol. Again anyone fitted front and then added rears later on that can comment on gains or lack of?
Car is a road car not track but want it to handles really well. It is S2+ if that makes any difference to your answers.
Actually also unsure about cts throttle pipe upgrade and discharge pipe. Not after WMI at the moment.
Thanks in advance.
Offline berg
  • -Given: 49
  • -Receive: 38
Re: After some advice please.
« Reply #1 on: July 31, 2014, 04:21:07 pm »
bigger brakes always worth it.
front ARB not sure how much difference it makes on its own tbh as fitted bothj at same time.
pipes wont make much difference but every little helps and flow should be improved
Offline ED300888
« Reply #2 on: July 31, 2014, 04:23:33 pm »
Thanks for your input berg. The fronts I have been told make a big differance but rears almost none with only having 20-25% braking responsibility. Just don't want to spend £200 for nothing, same with arb.
When you fitted both did the car handle much better?
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #3 on: July 31, 2014, 05:12:21 pm »
Brakes brakes brakes Gavin!
S-ALK & front wishbone bush, RARB with your B12 will make a great handling car  :drinking:
Offline ED300888
« Reply #4 on: July 31, 2014, 05:15:34 pm »
Better had be Gray! The pss have arrived too :-)
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #5 on: July 31, 2014, 05:41:19 pm »
Passenger ride soon then  :party:
Offline ED300888
« Reply #6 on: July 31, 2014, 06:50:13 pm »
Yes mate  :driver:
Offline ED300888
« Reply #7 on: July 31, 2014, 07:22:22 pm »
Anyone else had experience?
« Reply #8 on: July 31, 2014, 08:56:15 pm »
i fitted r32 fronts first on my gttdi and were excellent but i found the car to be nose divin at the front--when i put the rears on it balanced the braking out better
Offline ED300888
« Reply #9 on: July 31, 2014, 09:01:44 pm »
Cheers Maxitrol, exactly what i'm after.
Rear brakes are happening then. Just front arb to confirm then. Will forget pipes for now.
« Reply #10 on: July 31, 2014, 09:14:35 pm »
if your not taking the car on the track i wouldnt replace the front anti roll bar
  • -Receive: 427
« Reply #11 on: July 31, 2014, 09:29:16 pm »
Your stage2+ with standard anchors!!  :scared:
Add rear S3 rear calipers to your wish list, slightly bigger piston and uses larger 310mm vented discs so a win win.  As Maxitrol mentioned, it's about brake bias.
Def get the SALK and front Superpro wishbone bushes done along with lower engine mount and dog bone bush (personal preference but I'd recommend Vibra Technics). If you REALLY want to help further reduce wheel hop then add some side mounts too.
With the aftermarket ARB's being adjustable if you add both a front and rear then you can adjust to you own preference.
« Last Edit: July 31, 2014, 09:39:20 pm by MC71 »
Offline ED300888
« Reply #12 on: July 31, 2014, 09:36:56 pm »
Thanks mc71. Yes mate it can be interesting with 400ftlb lol.
Shopping list for up coming weeks -
H&R Arbs
S3 breaks all round with decent pads, disks and braided hoses.
B12 bilsteins with the eibach springs.
Super pro anti lift
Already done dog bone mount and all power mods besides wmi and bigger turbo/manifold but may give them all a miss for a while.
Offline ED300888
« Reply #13 on: July 31, 2014, 09:41:14 pm »
As just used as a fast road car avoiding poly bushes.
  • -Receive: 427
« Reply #14 on: July 31, 2014, 09:46:15 pm »
Also Change your Top Mounts to the Audi TT ones while your having your Coils fitted too, a worthwhile update.
I'll be adding the CTS discharge and TB pipes to mine, by all accounts it does seem to be a good supporting mod for peeps running higher power.
