Author Topic: Air ride  (Read 2234 times)
Offline Tommyt90
Air ride
« on: August 04, 2014, 07:11:06 am »
When you do the electrics and put it to the fuse box next the the steering wheel which 1 does it go to. ATM where mine is every now and then I come back toy car and esp steering wheel light and another light come on then go out after a while.
Offline xjay1337
  • -Receive: 377
Re: Air ride
« Reply #1 on: August 04, 2014, 08:54:03 am »
Repeat in english?
Offline Bennz
Re: Air ride
« Reply #2 on: August 04, 2014, 09:06:56 am »
Lol that was some mysterious language
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Air ride
« Reply #3 on: August 04, 2014, 09:16:50 am »
would help if you can tell us which air ride you exactly are fitting, what is IT that you are connecting to the fuse box.
Offline Tommyt90
Re: Air ride
« Reply #4 on: August 04, 2014, 12:58:19 pm »
Sorry was at like 7 this morning. Got airride v2 but was wondering what fuse it goes to. At the moment every now and then my car must sort off trip out or reset it's self as the clock has been changed. There are lights on my dash that stay on for like 15/20 minutes. The traction control light the steering wheel light and another light comes on. Then after 15/20 they clear. Just wondering wether it's been put to the right fuse
Offline cuprajake
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,72567.0.html
Re: Air ride
« Reply #5 on: August 04, 2014, 02:36:31 pm »
Fused live from the battery to the boot, then a off live to a relay to turn it on would be the best option. Then your not hacking up your fuse box.
Tornado red ed30 #0728
Offline stuart-88
  • -Receive: 21
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,101197.0.html
Re: Air ride
« Reply #6 on: August 04, 2014, 05:12:52 pm »
There's a spare 12v ignition live in the fuse box. Or are you talking about the main power feed? As already said above, that should be fused straight from the battery.
Instagram: stu_nc88
Offline Tommyt90
Re: Air ride
« Reply #7 on: August 04, 2014, 05:46:51 pm »
There is 1 from the battery then one what goes to the fuse. Should it be a separate 1 on the fuse.
Offline cuprajake
Re: Air ride
« Reply #8 on: August 04, 2014, 06:34:38 pm »
You need to look at your wiring diagrams.
The compressors use a huge ammount of power.
When ever I've done my installs I run a 0awg cable from the battery to a split terminal. Fused to about 60/8/amp. Then another feed from the iggnition
I run relays off these so the relay can be individually fused and take the brunt of the power. Not the cars harness and components.
If your not sure give it to some one who can, or it's a fire waiting to happen imo
