Author Topic: rear abs sensor broken off  (Read 1998 times)
Offline slider955i
  • you are only here once so enjoy
« on: August 05, 2014, 06:13:40 pm »
hi guys as title says plastic rear abs sensor broken off , question if i remove brake disc would i be able to see sensor so that i can knock it out with a pin punch
thanks in advance
gt sport 170 tdi , p - torque stage 1 map 208 bhp 338 ft lb
powder coated gunmetal alloys and caliper colour change
Offline Viking
  • -Given: 17
  • -Receive: 47
Re: rear abs sensor broken off
« Reply #1 on: August 05, 2014, 06:25:16 pm »
It'll help if the disc is out of the way. But it's a chew on getting them out when they're snapped off. I used a small screwdriver to punch a hole through the remaining bit, and a pair of long nosed pliers to pull bits out until I got it all.
Sarcasm for free. Anything after that can only be considered as a bonus.
Just because you think you know something, doesn't make you an expert if you've just read it on the internet, y'know.
Offline slider955i
« Reply #2 on: August 26, 2014, 03:26:47 pm »
problem diagnosed as wheel bearing cracked in the end , grrrrr
Offline slider955i
« Reply #3 on: August 26, 2014, 06:03:32 pm »
not wheel bearing sorry but the sensor ring had broken and worn through abs sensor but it all comes complete with wheel bearings etc another £300 plus lighter but glad to have it back working perfect
Offline DDM
« Reply #4 on: August 26, 2014, 07:23:58 pm »
£300.00????? are you having a laugh, mine did this just the other week, full wheel bearing was £39.00 inc vat, granted I didn't need a sensor but they don't cost another £260.00 to buy that is for sure. only take 30 ins max to fit too,
Offline slider955i
« Reply #5 on: August 27, 2014, 08:54:04 am »
stealers again , sensor had broken off originally which i had caused and could not be bothered to sort it , then they found ring broken which they showed me , it had worn a groove in end of sensor , i suppose if i had done it myself ( engineer) i would have saved a bomb but cannot be bothered
« Last Edit: August 27, 2014, 09:01:13 am by slider955i »
Offline slider955i
« Reply #6 on: August 27, 2014, 08:55:01 am »
thry charged a lot more than £39 for the bearing assembly
