Author Topic: Brakes.  (Read 800 times)
Offline Viking
  • -Given: 17
  • -Receive: 47
Brakes.
« on: August 05, 2014, 09:09:36 pm »
Daughter came home the other day and said "Why did my brakes not work?"
Digging as little further, it transpires that she was driving along, went to brake, and the pedal hit the floor. Slowed down, braked again and they worked.
Had a look this morning and thought "Oi oi, pads are getting down a bit!." so got some new ones and fitted this evening. This is what came off.
So, looks like the pad material on one side has let go and buggered off, leaving a fair old gap to make up on the next pedal press, then it went down to metal and contact made, and the brakes worked again. So new pads & discs fitted and all working again.
Sarcasm for free. Anything after that can only be considered as a bonus.
Just because you think you know something, doesn't make you an expert if you've just read it on the internet, y'know.
Re: Brakes.
« Reply #1 on: August 05, 2014, 09:11:59 pm »
could of been a bit naughty that--If your daughter is like mine i bet you payed for them :signLOL:
« Last Edit: August 05, 2014, 09:21:07 pm by maxitrol »
Offline Viking
  • -Given: 17
  • -Receive: 47
Re: Brakes.
« Reply #2 on: August 05, 2014, 09:19:23 pm »
Yes mate. You know the score, same as me. Still, worth it to know she's less likely to run up the arse of someone.
Offline flashp
  • -Receive: 65
Re: Brakes.
« Reply #3 on: August 05, 2014, 09:48:38 pm »
I think I'd want a closer at the calipers if the pad wear was that uneven  :surprised:. They're OK now till they wear again but I'm sure you have another problem there to fix.
Gone but not forgotten :-)
Offline Viking
  • -Given: 17
  • -Receive: 47
Re: Brakes.
« Reply #4 on: August 05, 2014, 09:57:44 pm »
It's not uneven wear, it's the pad friction material which has detached from the back plate. It was there before when I checked a month ago, and detached suddenly.
Offline flashp
  • -Receive: 65
Re: Brakes.
« Reply #5 on: August 05, 2014, 10:12:43 pm »
Hmmm...can't for the life of me see how it got out from the caliper housing. I don't dispute what you're saying but I can't believe it happened the way you say, I really don't think it just fell off.
Update - just googled this and it's not unheard of so I'll stand corrected if this is the case. Most cases seem to be on older cars mind you.
Looking at the pads you've pulled it looks like two of them are much older than the others ??
« Last Edit: August 05, 2014, 10:31:00 pm by flashp »
Offline Viking
  • -Given: 17
  • -Receive: 47
Re: Brakes.
« Reply #6 on: August 05, 2014, 10:22:42 pm »
You mean you've never seen pads detach their material before. I've seen it a few times over the years, but not recently. Usually it's a feature reserved for budget pads.
Offline marko
Re: Brakes.
« Reply #7 on: August 05, 2014, 10:25:31 pm »
Wow!!!!....lucky girl there.bit of a freak one that
Offline flashp
  • -Receive: 65
Re: Brakes.
« Reply #8 on: August 05, 2014, 10:27:11 pm »
Nope, never. I could understand some quality issues with cheaper pads with issues such as fit etc, but never something as fundamental as this.
Re: Brakes.
« Reply #9 on: August 05, 2014, 10:39:15 pm »
see this all the time at work even to the point where the brake caliper piston is being used as the pad :surprised:
Offline flashp
  • -Receive: 65
Re: Brakes.
« Reply #10 on: August 05, 2014, 10:48:39 pm »
Any particular vehicle manufacturers or models? Have you noticed any particular brands affected more commonly?
Re: Brakes.
« Reply #11 on: August 05, 2014, 11:07:04 pm »
no just ones that dont see a garage for serving
