Author Topic: Removing bootlid badge  (Read 680 times)
Offline Black9
  • -Given: 35
« on: August 06, 2014, 01:51:10 am »
What's the safest way to do this without damaging paint. It's on the bootlid off a CLK55.
Any ideas? The perv owner has added it himself so hasn't been on for that long
Offline Matto
  • -Receive: 116
Re: Removing bootlid badge
« Reply #1 on: August 06, 2014, 07:49:26 am »
If it's one of these that just sticks on with the double sided foam, I tie some fishing line between 2 screwdrivers then pull the line behind the badge like a cheese wire. Then use some tar and glue remover to remove the backing or sticky residue that's left.
dansmith180
« Reply #2 on: August 06, 2014, 08:30:32 am »
I normally heat it up a bit then get some floss behind it and remove all the residue with tar and glue remover.
Offline Black9
  • -Given: 35
« Reply #3 on: August 06, 2014, 12:25:21 pm »
Thanks. I'll try some fishing line or similar :-)
