Depends on driving style mainly, if you put the suspension under constant stress then you'll get far less life. The catch is that stiffer springs will reduce the workload (additional to the constant strain the dampers are permanently under) so its a bit of pot luck.
Also look at getting Audi RS3/TTS top mounts. Not much more in cost but much better than VW OEM parts.
