Author Topic: PolarFIS (Advanced) : New Update v0.4.4 [06-08-2014]  (Read 1514 times)
« on: August 06, 2014, 03:59:00 pm »
***** Improvements / Update description for RED, WHITE and COLOR cluster *****
  • Improved Engine ECU Diagnostics communications
  • Modified Engine ECU Identification, if a Engine ECU is not supported, it will be displayed in screen and
 not keep "Identifying available parameters" as in previous firmwares.
  • Solved issue that caused wrong Lambda readings
  • Improved engine ecu database
 - For ECU reference 03L 906 022 QD, improved reading of Regeneration Status and Differential Pressure (mbar)
 - For diesel ECUS, improver reading of Soot Load and !Soot Load
 - For petrol TP ECUS, added Misfires sum parameter
  • Added new parameters:
 - EGT S1: Exhaust gas temperature Sensor 1
 - EGT S2: Exhaust gas temperature Sensor 2
 - EGT S3: Exhaust gas temperature Sensor 3
 - EGT S4: Exhaust gas temperature Sensor 4
  • Improved communication with aftermarket radios
For install this update, please use ActiveX from our official web www.auto-polar.com (Update Zone)
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=5oqs8ulm6218pe2fi3mnglafuh&/topic,19740.0.html
Re: PolarFIS (Advanced) : New Update v0.4.4 [06-08-2014]
« Reply #1 on: August 06, 2014, 04:01:22 pm »
I wish they would do a "big gear" screen
« Reply #2 on: August 06, 2014, 04:10:33 pm »
It's on a wish list at Polar but I doubt it'll find its way into a near future firmware.
« Reply #3 on: August 06, 2014, 04:29:13 pm »
They are missing a trick there.  :sad1:
« Reply #4 on: August 06, 2014, 04:47:39 pm »
Big gear? What do you mean?
« Reply #5 on: August 06, 2014, 04:50:15 pm »
To show what gear you are in.. instead of the little 1 2 3 4 5 6, it shows a big 5 in the display
« Reply #6 on: August 06, 2014, 04:52:51 pm »
Aaah that would be cool, yeah  :happy2:
