Author Topic: Need some advise on offside creaking knocking noise  (Read 628 times)
Offline tigerj360
« on: August 07, 2014, 03:01:43 pm »
My car recently went through its MOT and had an advisory that the drivers side CV boot had a split, which was causing the knocking/creaking when on full lock turning right.
Took the car to my local garage yesterday and had the CV replaced but its still creating the same noise. The guy said I may have left it to long and now its the drive shaft making the noise. Just wondering if that sounds like the correct diagnosis and if so how much should I be looking to pay to get a Offside drive shaft replaced?
Cheers Guys!
Jon
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=g0h830f9amicecsicl3fr4qrvh&/topic,90967.msg917089.html#msg917089
Re: Need some advise on offside creaking knocking noise
« Reply #1 on: August 07, 2014, 03:18:26 pm »
Did they dismantle and clean the joint or just stretch a boot over the top?
My car makes a creaking noise at full lock going up my drive which is very steep.
05 | Tornado Red | DSG
Offline tigerj360
« Reply #2 on: August 07, 2014, 03:27:12 pm »
They completely replaced the Boot as there was a big slit in it. Not sure if they cleaned the joint but guessing they would of.
Its an annoying noise right!?
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #3 on: August 07, 2014, 03:42:32 pm »
Wouldn't be dodgy coil spring, mounting bearing kit?
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #4 on: August 07, 2014, 03:51:52 pm »
When i bought my car both boots were ripped. Went to a local garage they said they would stretch a boot over the top without dismantling the joint. As the boot had been ripped for a while i decided to do it my self and dismantle the joint. Any dirt grit could cause a failure (new joint and shaft). Also i could inspect the joints for damage. This only happens going up my drive so i'm not to worried.
Offline tigerj360
« Reply #5 on: August 07, 2014, 04:00:11 pm »
I have no idea mate, can only go by what the garage has told me  :sad1:
Called up the local VW/Audi specialist and they have quoted 260 for a new shaft fitted. Doesn't seem to bad?
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #6 on: August 07, 2014, 04:40:15 pm »
My bearings and coils went on previous car and had same noises you're explaining!
I'd check that first if i were you! Although it is messy to get at the bearings you can check coils very easily
