Author Topic: VW Dealers have never heard of a 'diverter valve'  (Read 9002 times)
Offline grey golfster
  • -Given: 79
Re: VW Dealers have never heard of a 'diverter valve'
« Reply #15 on: August 08, 2014, 12:17:31 pm »
Had a v similar experience wrt the fuel pump cam follower, at vw main dealer on the Wirral.
What is that? Why would you want to change it? Never heard of any problems, and had never sold the parts to anyone else!
Is it some sort of plausible deniability/emperors new clothes type strategy on behalf of vw? Are there just too many numptys employed?
People still knock the 70's British Leyland mentality of letting customers develop/beta_test your products for you...it is obvious that VAG have been doing a similar thing for years.
Offline J400uk
  • -Receive: 27
« Reply #16 on: August 08, 2014, 12:43:14 pm »
I don't think its VW denying stuff, more just dealers employing people who aren't particularly knowledgeable! Ok for basic routine servicing and warranty work when there's a TPI to follow, but nothing more complex.
Offline MateyGuv
  • -Given: 32
  • -Receive: 67
  • Instagram & YouTube - mateyguv
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,69555.0.html
« Reply #17 on: August 08, 2014, 12:55:45 pm »
Iv just had to near enough justify buying rear brake dust shields off Audi (got a set of S3 rears to fit) in Cheshire Oaks as I couldn't supply a reg number for a car. I supplied the part number and the guy got high and mighty cause I described it as a dust sheild - it's called something else officially but FFS
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #18 on: August 08, 2014, 01:52:36 pm »
Cover plate for brake disc.  :happy2:
Sarcasm for free. Anything after that can only be considered as a bonus.
Just because you think you know something, doesn't make you an expert if you've just read it on the internet, y'know.
Offline MateyGuv
  • -Given: 32
  • -Receive: 67
« Reply #19 on: August 08, 2014, 02:46:56 pm »
Cheers bro  :grin:
Offline duncatr
« Reply #20 on: August 08, 2014, 03:19:55 pm »
It makes a massive difference when you find a decent parts guy from someone who always needs the correct name / number and chassis number!!
Different companies call them different things too so if he is more familiar with other makes he will call it a dump valve or re-circ valve.
Offline Matthewsimone
  • -Receive: 39
« Reply #21 on: August 08, 2014, 07:43:06 pm »
Just ordered revision G dv
£37
Wish me luck fitting it  :confused:
Where exactly is valve located on 2007 gti K03 please
Sorry to hijack thread  :notworthy:
Offline phatmuther
« Reply #22 on: August 08, 2014, 10:09:33 pm »
It's just below the turbo. You can get to it by taking the wheel and arch lining off, then it's just above the drive shaft. Just swapped mine, not too bad a job really. Not sure it's fixed my problem though  :sad1:
  • -Receive: 39
« Reply #23 on: August 08, 2014, 10:52:18 pm »
Thanks mate
Valve should be here mon/tues so will give it a go!
Can it not be done from underneath then?
Offline phatmuther
« Reply #24 on: August 08, 2014, 11:30:38 pm »
Yeah should be able to no problem, just won't be able to see the top bolt so easily  :grin:
Offline Rossimac
  • -Given: 78
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,90767.0.html
« Reply #25 on: August 09, 2014, 08:08:42 pm »
Volkswagen Agnew Boucher  in Belfast were the same last week when I went to the parts department to as for a quote for PCV and DV. They had no idea about the part and then the technician came out from the back and agreed that I was probably wrong.
After explaining these forums suggested it (and after VCDS said my pcv was faulty) they chuckled at the forums folk as if we are the idiots who know nothing...
Oh well, off to TPS for me. Got my quote very quickly for all parts. Very impressed.  :booty:
Offline Georrge
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,93533.msg937034.html#msg937034
« Reply #26 on: August 10, 2014, 10:04:15 pm »
My car is booked in for Thursday so I'll mention it to someone face to face there, but I bet they charge a few quid to actually check it  :signLOL:
Instagram @george_kersh
Offline JIEEE
« Reply #27 on: August 10, 2014, 10:25:34 pm »
Haha I'd run out the door and not look back.
Offline Georrge
« Reply #28 on: August 11, 2014, 08:40:52 am »
Hahahaha, I'll see how it goes.. I'll be sure to give an update when I get my car back  :happy2:
Offline Georrge
« Reply #29 on: August 14, 2014, 04:20:03 pm »
Forget the diverter valve, just got a call from them saying I need both draft shafts replacing costing over £550! On top of that I need new pads and discs, which I was aware about as it had it's MOT a few weeks a go and that was flagged up. So I'm pretty bummed out about this £139 service costing me over £1K!  :scared:
On the up side, they're updating my RNS 510 firmware for £25  :signLOL:
