Author Topic: rvc wiring, what wire does what on the rns plug.  (Read 2846 times)
Offline Kev
« on: August 08, 2014, 10:47:41 am »
Wiring big help I need to know what wire does what there are 5 wires that go into the multi plug on the back of the rns for the reverse cam on one side therse orange brown black black is thick, green and blue on the other.
Offline StephenED30
  • -Receive: 53
  • Edition 40 No 135
Offline Kev
Re: rvc wiring, what wire does what on the rns plug.
« Reply #2 on: August 08, 2014, 12:34:35 pm »
Hi mate its the coaxial cable I need to know what each wire does as I think I have a problem with it.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #3 on: August 08, 2014, 12:37:47 pm »
if you have a problem check each wire with a multimeter
are you getting the message when you select reverse?
Cluster and Key coding
Location Great Yarmouth
Offline Kev
« Reply #4 on: August 08, 2014, 12:51:20 pm »
No no message at all mate I just need to know what each wire  does.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #5 on: August 08, 2014, 12:58:32 pm »
then you need to post up what your coding is
Offline Kev
« Reply #6 on: August 08, 2014, 01:07:54 pm »
Ok do you know what each one does as my friend as poped up to mine to test them but doesn't know what each wire should be giving him.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #7 on: August 08, 2014, 01:15:02 pm »
when I say test them see if there is a break in one of them
you would need some cable and you will have to test them on the plug that plugs into the camera
Offline Kev
« Reply #8 on: August 08, 2014, 01:36:30 pm »
Ok thanks, my friend says do you know what I should be getting at the front he said he could do with a wiring diagram so he knows what each one should be doing.  :happy2:
Offline SI-R32
  • -Receive: 125
« Reply #9 on: August 08, 2014, 02:42:05 pm »
the cables carry the RGBs video signal you may find that you can measure a voltage with them but in all honesty unless you have specialist equipment you won't be finding any signals there.
what you actually trying to do, did you remove them to get it through the hatch now don't know where they go back?
Offline Kev
« Reply #10 on: August 08, 2014, 03:06:02 pm »
No mate I did take the blue plug off but that only goes back one way, my mate is a sparky but he just needs the wiring diagram so he knows what each one should be  :happy2:
Offline SI-R32
  • -Receive: 125
« Reply #11 on: August 08, 2014, 03:28:34 pm »
well the problem is many different companies will use different coloured cables to send the signal down if you cross reference this link to the pins your cable is connected to you will find which one is red, green, blue, sync and ground
http://www.my-gti.com/529/volkswagen-rns-510-pin-assignments
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #12 on: August 08, 2014, 03:31:45 pm »
would it be easier just to get another coaxial cable? If it still dont work at least you may be able to sell it on and eliminate that the coaxial is faulty, could be a fault with the camera all along
Offline Kev
« Reply #13 on: August 08, 2014, 03:54:12 pm »
It would if I hadn't of just bought it mate im also thinking of fitting the kenwood unit dnx520vbt which ive just spoke to a kenwood specialist in bradford and there sure they can make me a new plug to fit they just need to know what does what, Help.!!!!
Offline SI-R32
  • -Receive: 125
Re:
« Reply #14 on: August 08, 2014, 03:57:26 pm »
They won't be able to make a plug to fit I'm afraid as the output of the VW camera is quite specific to VW, you can however change the rgb camera for a composite video camera still from VW that will work with after market stereos
