November 28, 2024, 04:07:55 am
All Things Mk5
How to Guides / Troubleshooting
Induction flutter
Topic: Induction flutter (Read 4744 times)
Carl123
Always Involved
-Given: 1
-Receive: 0
Induction flutter
August 08, 2014, 10:16:26 pm »
Abit new to this but I've seen a fair few that have the flutter when revving etc but mine only makes the whoosh noise couldn't explain that noise any better lol can any1 tell me how or why these vary cheers also I have a forge twintake
GTI-Ross
Just look at my post count
-Given: 5
-Receive: 26
Learning All The Time :)
Re: Induction flutter
Reply #1 on:
August 08, 2014, 10:39:58 pm »
You usually get the flutter if you double rev, its the gas dumping or in VW recirculating it. If you just do a big rev you will get a single wooosh.
Some intake are also more prone to hearing the flutter / dump sound.
Spankiee
Always Involved
-Given: 0
-Receive: 20
Reply #2 on:
August 08, 2014, 10:41:42 pm »
My itg only gives like a woosh not the turkey noise
candy white edition 30
Carl123
Always Involved
-Given: 1
-Receive: 0
Reply #3 on:
August 09, 2014, 01:00:08 pm »
Cheers for feedback guys
NathED30
Always Involved
-Given: 6
-Receive: 0
Reply #4 on:
August 13, 2014, 11:21:53 am »
I've got an itg on my edition 30
If u build up boost then let off throttle and tap the accelerator peddle it makes the flutter
Reflex Silver Edition 30 #0063
rich83
-Given: 165
-Receive: 802
My Ride:
Reply #5 on:
August 13, 2014, 11:27:02 am »
The on full throttle boost flutter you hear is the wastegate regulating boost.
https://www.justgiving.com/thenational3peaks
Pikey Motorsports
-Given: 29
-Receive: 34
Reply #6 on:
August 14, 2014, 07:15:50 pm »
Depending on your recirc valve setup varies on the sound.. You will get the noise all the time if you have a forge recirc with a strong spring
TSR PERFORMANCE GTX30 520BHP
LITCHFIELD R35 GT-R 660BHP
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
john87
Won't Shut up.
-Given: 11
-Receive: 53
Reply #7 on:
August 15, 2014, 10:01:36 am »
As satisfying as it sounds, I thought that induction 'flutter' is a sign of compressor surge? i.e. compressed air being forced back through the turbo's compressor vanes, due to the DV setup not opening enough when required?
Saintsteve
Reply #8 on:
August 15, 2014, 07:03:25 pm »
Quote from: Scottymon on August 15, 2014, 10:53:25 am
^ yes, I thought something similar that flutter w bad, stalling.
Correct
Bo!
Always Involved
-Given: 0
-Receive: 3
Reply #9 on:
March 25, 2016, 07:26:09 pm »
Hi .
Old thread but hoping for a response. I've just fitted a forge twintake to my BWA engine GTI K03, it's totally stock apart from the twintake .
I don't get any chatter unless I tap the throttle a few times on boost other than that it is just a woosh! And darth Vader noise under load Is this normal. Was thinking I may have a faulty DV or something. after reading this thread am I correct in thinking this is a good thing that I'm not getting loads of flutter or not .
Adam0604
Won't Shut up.
-Given: 16
-Receive: 34
My Ride:
Reply #10 on:
March 25, 2016, 10:26:15 pm »
Think it's normal. Tap the accelerator again just as you come off the gas and you should get the flutter sound.
All Things Mk5
Induction flutter
