Author Topic: RNS510 map zoom issue  (Read 8340 times)
Offline V2 FAN
  • Porsche 911 inbound
Re: RNS510 map zoom issue
« Reply #15 on: September 14, 2014, 07:19:19 pm »
This isn't an issue with the autozoom. I've tried that. I believe it's a bug in the 4120 firmware. I just need to find out what other firmware I can go to.
I had this issue and it was driving me  :pomppomp:
I changed my firmware and instantly no more issues so it looks as thou there might be a little gremlin in the firmware :indifferent:
Offline Matto
  • -Receive: 116
« Reply #16 on: September 14, 2014, 10:22:48 pm »
What rev unit and firmware you running @V2 FAN?
« Last Edit: September 17, 2014, 12:32:29 am by Matto »
Offline mrxbox360
  • My Ride: 2008 Golf Mk5 GT TDI Sport 5dr Reflex Silver Personal Enchanced
« Reply #17 on: September 18, 2014, 07:15:49 pm »
My rev c running v11 maps & josi 5238 firmware is having the same problem
Offline Matto
  • -Receive: 116
« Reply #18 on: September 18, 2014, 10:38:07 pm »
Annoying isn't it. I'm thinking of going back to 3970 with V10 maps. I can live without radio text.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #19 on: September 19, 2014, 01:18:10 am »
Try just going to maps V10 or to firmware 4120 modified. There are newer firmwares that solve this issue but I don't know a good link to them. One is 5274 modified. My version P fortunately doesn't have this issue with 5238 modified and V11 maps.
Offline Matto
  • -Receive: 116
« Reply #20 on: September 19, 2014, 02:03:04 pm »
I went to V10 maps on the 3970 firmware and was ok. Went to 4120 not having the issue. I'm still on the V10 maps. I did a little research and found a firmware version that was supposed to be good for most units. Cannot remember what it was now though as I get fed up of looking.
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #21 on: September 19, 2014, 03:15:18 pm »
I've not had any zoom issues with firmwares I've loaded...  :party:
Sarcasm for free. Anything after that can only be considered as a bonus.
Just because you think you know something, doesn't make you an expert if you've just read it on the internet, y'know.
Offline Matto
  • -Receive: 116
« Reply #22 on: November 30, 2014, 09:30:05 pm »
Just as an update on this, I have returned back to 3970 this weekend and the map zoom issue seems to have sorted itself. It also retained the radio text function.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #23 on: November 30, 2014, 11:34:35 pm »
(...) It also retained the radio text function.
That was lucky! :surprised:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=cfqpecl35sf0s1k2klj33fo5oh&/topic,90967.msg917089.html#msg917089
« Reply #24 on: November 30, 2014, 11:43:22 pm »
My map is always in night mode when the light are on auto really annoying.
05 | Tornado Red | DSG
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #25 on: November 30, 2014, 11:49:01 pm »
Just to make sure I understood, your map is on night mode even when your lights are off but you have the headlight switch on auto function?
I know you can select the mode in the settings, but mine just go to night mode when my lights turn on. :confused:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #26 on: November 30, 2014, 11:54:37 pm »
Lights off >> Map Day Mode.
Lights On auto >> Map Night Mode (Headlights and dash lights are off as its sunny)
When i first installed it i'm sure it worked properly.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #27 on: December 01, 2014, 12:00:34 am »
Weird stuff. Have you tried changing the settings on the Setup menu to see if it syncs back to normal? :confused:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #28 on: December 01, 2014, 12:04:44 am »
I've not touched any of the settings. I will give it a go.
Offline Matto
  • -Receive: 116
« Reply #29 on: December 01, 2014, 10:45:45 am »
That's what I thought but for me getting the zoom issue sorted outweighed the radio text function. It has also retained the Autozoom aswell. Not sure if that was a featured added to later firmwares.
I did find that updating the firmware changes which model you have. Mine started out as a Rev H, and with the 5274 went to a Rev P. Now its a Rev F  :signLOL:
