Author Topic: bought a pressure test kit?  (Read 1285 times)
Offline Markyed30
« on: August 09, 2014, 05:24:01 pm »
Right I bought a pressure test kit connected it up but was pressurising my crank case air coming out of dip stick
Put it all back together and started it and burnt off a good bit of oil, Googled and alot of people have did the same what do I need to bung to stop this and do a proper test any ideas??
Offline Shaw
Re: bought a pressure test kit?
« Reply #1 on: August 09, 2014, 07:00:43 pm »
To pressure test what?
'07 Mk5 GTI Manual
Offline Markyed30
« Reply #2 on: August 09, 2014, 07:30:46 pm »
Connects at turbo and tests for leaks under pressure like this
http://thumbs3.ebaystatic.com/d/l225/m/mcqs1m7FeSNDrhcdzDtzicg.jpg
Offline adgti
« Reply #3 on: August 09, 2014, 09:07:36 pm »
You can test it like you have & remove the oil cap or test in sections
pipe from turbo then blank off the throttle body pipe also blank off breather pipe during the test
Offline Shaw
« Reply #4 on: August 09, 2014, 09:26:06 pm »
Pressurising the crankcase may point to a failed PCV
'07 Mk5 GTI Manual
Offline Markyed30
« Reply #5 on: August 09, 2014, 09:41:33 pm »
Iv got a PCV revamp if I remove the oil cap it won't work as it just spits air out it
