Author Topic: Peeps running H&R Trak spacers on the front...  (Read 387 times)
Offline mrzed
« on: August 10, 2014, 11:29:50 am »
Im going to order some 10mm spacers for the fronts but there are 2 parts numbers, 2055571A & 2055571B...which ones did you get? They're identical other than the Hub Height and bevel depth.....
Chris
Re: Peeps running H&R Trak spacers on the front...
« Reply #1 on: August 10, 2014, 01:46:27 pm »
You really need to measure the hub protrusion height to be completely sure but either should do.
iirc the rear needs the A version because of the bigger hub protrusion.
I used the A version on the front and had no issues with fitment.
