Author Topic: Ed30 rear light cluster  (Read 1573 times)
Offline Krisbrown89
« on: August 10, 2014, 03:20:38 pm »
My rear light on the boot is steaming up and by the looks of things someones had a go at sealing it. I'm just going to buy a new unit and be done with it, ive found a replacement on ebay however its for Lhd and they have the fog light on the left as opposed to the reverse light. I would just like to know if i buy the unit would it be easy enough to swap the inner lenses over?
Offline biffobear
Re: Ed30 rear light cluster
« Reply #1 on: August 10, 2014, 05:27:19 pm »
Then you would have the same problem again trying to seal them
Offline Krisbrown89
« Reply #2 on: August 10, 2014, 06:13:40 pm »
Suppose. I'll probably just buy a new unit if thats the case then.
Cheers anyways.
Offline biffobear
« Reply #3 on: August 10, 2014, 07:43:03 pm »
If you take the old one off, put a bead of silicone round it then turn a hairdryer on into the inside, leave it on until all condensation is removed and it should be ok
Offline Dave J
  • -Given: 45
  • -Receive: 63
« Reply #4 on: August 10, 2014, 08:11:21 pm »
It's pretty easy to swap the inner clear / red lens on the tail lights - just a couple of tools and patience needed.
Have removed one on a LHD ED30 light as I want to put the clear lens in place of the red fog lens on my UK car (of course with a silver tinted red bulb to remain legal).
Have some pics if you need them  :smiley:
Edition 30 - no. 1387
Offline Krisbrown89
« Reply #5 on: August 10, 2014, 08:36:44 pm »
Would appreciate it dave if you could put some pics up please mate so it would give me some sort of idea cheers.
Offline Dave J
  • -Given: 45
  • -Receive: 63
« Reply #6 on: August 15, 2014, 09:12:37 pm »
Sorry for a late reply!
I haven't removed the rear lights from my car, but have read it is quite straightforward.
Once you have the inner light out, you need to undo the reflector housing / bulb holder (Philips screwdriver needed), and you should end up with the following;
In the pic above you can see the plastic lugs of what is the plastic red fog light / clear reversing lens - you just need to carefully press in the lugs one at a time and then you can remove the filter;
Hope this helps!
Offline Krisbrown89
« Reply #7 on: August 18, 2014, 03:13:20 pm »
Thanks very much dave
