Author Topic: squeaky auxiliary belt  (Read 3167 times)
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« on: August 10, 2014, 08:02:48 pm »
I've recently replaced the auxiliary belt as it was squeaking a lot when cold not constantly just when you hit the gas.
The tensioner seemed good but i'm still getting a squeak now and then. Any suggestions?
05 | Tornado Red | DSG
Offline skard
  • -Receive: 245
Re: squeaky auxiliary belt
« Reply #1 on: August 10, 2014, 08:29:46 pm »
Test the alternator clutch pulley
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #2 on: August 11, 2014, 03:20:35 pm »
I think you might be right on the money with that one. The pulley will not move when i lock it with a screw driver.
Ive seen two types from INA
Metal 30.76
Plastic?? 54.60
Any big differences in these apart from the price?
Offline skard
  • -Receive: 245
« Reply #3 on: August 11, 2014, 04:47:15 pm »
The INA one I put in was about £30 from GSF a couple of years ago, and it's metal.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #4 on: August 11, 2014, 06:56:07 pm »
thanks again for getting back to me. I'll order the one for 30 the dealership wanted €98. Even with the shipping to Spain i'll still be saving a bit of cash.
Now i need the thing to remove it whats the best option?
Offline skard
  • -Receive: 245
« Reply #5 on: August 11, 2014, 07:03:35 pm »
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #6 on: August 11, 2014, 08:06:35 pm »
I have a tool like this that works fine (can probably find it cheaper, that's just the first link I found)
http://www.ebay.co.uk/itm/VW-Audi-Seat-Skoda-VAG-Alternator-Pulley-Removal-Wrench-Tool-Star-Torx-T50-1-2-D-/251599110106?pt=UK_Hand_Tools_Equipment&hash=item3a9479bfda
I already have a T50 so should i just buy the 33 tooth adapter separately?
Offline skard
  • -Receive: 245
« Reply #7 on: August 11, 2014, 08:20:53 pm »
You could I suppose
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #8 on: August 11, 2014, 08:27:22 pm »
You could I suppose
I saw a video and they removed it with a impact wrench. So if im not using an impact wrench the T50 needs to go through the centre of the 33 tooth piece?
Offline skard
  • -Receive: 245
« Reply #9 on: August 11, 2014, 08:33:35 pm »
I have done it both ways on my Golf's, the impact gun method being easiest. Yes the torx needs to go through the splined socket, it needs a bit of leverage to get it off hence why that tool is useful, but you could make it work otherwise.
By the time you buy a splined soocket with a hex end to get a spanner on it, you may be close to the price of buying the complete tool.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #10 on: August 11, 2014, 08:41:00 pm »
I have an electric impact wrench which saved my bacon when removing both front cv joints. But i doubt it will fit. I will buy the complete tool i suspect the T50 i have with adaptor will not fit through the splined socket. Thanks again for your help i will let you know how i get on.
Offline skard
  • -Receive: 245
« Reply #11 on: August 11, 2014, 08:45:54 pm »
Ok mate, good luck
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #12 on: August 19, 2014, 12:41:47 pm »
So the tool and part arrived today.
5 Minute job i thougth.
As usual i was wrong the T50 has snapped. The end is stuck in the nut.
What now remove the alternator and try impact wrench?? :sad1:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #13 on: August 19, 2014, 09:39:33 pm »
So i removed the alternator tried the impact wrench no joy.
Nipped out and bought another T50 "had to buy a complete set"   :sad1:
Snapped the T50 again. :sick:
Tried again with the impact wrench. This time i spun its clockwise then counter clockwise hoping the jolt would loosen it up. After about 4 attempts it came off.
Now i have to get the broken T50 out and put the car back together. Probably will have to buy another T50 so i can get the correct torque on it.
Any tips for getting the T50 out?
Offline john87
  • -Receive: 53
« Reply #14 on: August 20, 2014, 12:13:18 pm »
My R32 was squeaking when idling, turned out it was the water pump bearings!
Pump was replaced, noise gone (56k miles)
