Author Topic: Highline clocks  (Read 1062 times)
Offline D3hnt
Highline clocks
« on: August 11, 2014, 02:47:00 pm »
How do i know which clocks to get to do the retro fit?
The clocks in my 07 gti are 1k0 920 963
Can anyone help please?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Highline clocks
« Reply #1 on: August 11, 2014, 02:48:40 pm »
you should ideally stick to 973 or 974
Cluster and Key coding
Location Great Yarmouth
Offline usmangti
Re: Highline clocks
« Reply #2 on: August 11, 2014, 02:52:05 pm »
There is someone selling a 974 speedo in the classifieds.
Offline D3hnt
Re: Highline clocks
« Reply #3 on: August 11, 2014, 03:33:04 pm »
Thats why im asking this question to be honest, i been looking into doing this mod for ages, but cant get my head around it
How does coding, mileage correction etc work?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Highline clocks
« Reply #4 on: August 11, 2014, 03:41:29 pm »
You need your SKC code, as you have an 07 plate and if you dont have it, you will need Eddie or Kalu to extract it for you.
Once you have that, and the SKC for your new clocks (SKC for 970, 971 and 972 clocks can be extracted using VAG K+ Commander) then you can code it using VCDS.
Offline usmangti
Re: Highline clocks
« Reply #5 on: August 11, 2014, 05:13:09 pm »
Basically 973 and 974 are usually a bit more difficult to code. The guy who coded mine was able to do so as it was a early speedo ie 970/971/972.
But he wasn't able to extract the code from my mates 07 golf as it had the later speedo fitted. Something to do with the cable apparently. Eddie-nl can defo help you so worth giving them a PM.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Highline clocks
« Reply #6 on: August 12, 2014, 09:56:01 am »
973 & 974 I can do
You don't need the SKC for them as they are done differently
It does require the genuine Vag commander
Offline Shorty
  • -Receive: 24
Re: Highline clocks
« Reply #7 on: August 12, 2014, 04:57:57 pm »
Get them bought :)
| Mk7 R |
