Author Topic: HPA Intake Manifold  (Read 6982 times)
Offline bluo
HPA Intake Manifold
« on: August 12, 2014, 09:50:01 am »
Worth getting one or not? Anyone got any experience with them?
http://www.hpamotorsports.com/product_20tim.html
Offline Pikey Motorsports
Re: HPA Intake Manifold
« Reply #1 on: August 12, 2014, 11:24:10 am »
Not really unless running big power the standard one is fine with over 500hp
Useful for 4 port wmi tho and looks good
TSR PERFORMANCE GTX30 520BHP
LITCHFIELD R35 GT-R 660BHP
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #2 on: August 12, 2014, 11:40:33 am »
Very Nice looking !
HPA's Performance intake when combined with our STG2SR V1.01 calibration for FSI expands the powerband from 4600 through redline. Gains between 15 to 25 HP are seen through the upper RPM generating a new fresh pull out of your 2.0T!
Expand your 2.0T's Horizons
    2.0T Intake Manifold
    Featuring a 40% larger Plenum over OE
    HPA's intake outflows the OE Fsi intake by 24%
    HPA's intake outflows the OE Tsi intake by 12%
    Even distribution across all runners
    (tests run @28"H20/oe 57mm TB, WOT)
    Integrated flapper delete
    Direct bolt-on replacement for your OEM plastic
    Integrated Water Meth port
    Cast aluminum construction
    Durable oem powder coat finish
 :party:  :driver:  :party:
Silver is the way !
Offline bluo
« Reply #3 on: August 12, 2014, 01:33:27 pm »
So what you're saying is save the cash while I'm K04 and only spend it when I fit WMI?
Or I could get it, drill, tap and plug the 4 ports for WMI for a later date...
Love your build thread by the way!
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #4 on: August 12, 2014, 02:18:23 pm »
i have heard they should have issues with the cast so they aren't airtight, but i haven't been able to get it confirmed.
Over the top mod list ;o)
Offline bluo
« Reply #5 on: August 12, 2014, 04:05:17 pm »
Where did you hear that?
  • -Given: 243
  • -Receive: 154
« Reply #6 on: August 12, 2014, 04:39:09 pm »
Unconfirmed source, but as stated not verified. I myself are looking into these so i'm not biazed against the product.
Statllers might have more info as they sell and fit them  :happy2:
Offline bluo
« Reply #7 on: August 12, 2014, 06:02:36 pm »
yeah I called them, they must have been quite busy cause they were a little short on the phone so I thought I'd call another day.
« Reply #8 on: August 12, 2014, 06:47:51 pm »
The HPA manifold really needs a custom map to get the best out of it. Essential piece of kit if you are thinking about running 2bar plus on a BT conversion.
Offline bluo
« Reply #9 on: August 12, 2014, 09:33:07 pm »
I gathered as much from research a custom map would be needed. I'm still learning as I go along, can you explain the pressure thing, what will the currently be running with a K04?
Offline chudds
« Reply #10 on: August 12, 2014, 10:13:20 pm »
id wait for IE number if you was going to get one! they made 80bhp out of the 1.8t manifold running a big turbo inbetween the 300/400 some serious development has gone into this manifold!
for some reason i cant find a link to it atm :/
Offline bluo
« Reply #11 on: August 12, 2014, 11:53:53 pm »
If you do please post it up...
