Author Topic: AKS TTRS/DB9 Brembo + 362mm AP Review  (Read 34710 times)
Offline berg
  • -Given: 49
  • -Receive: 38
Re: AKS TTRS/DB9 Brembo + 362mm AP Review
« Reply #60 on: August 27, 2014, 02:56:48 pm »
I believe Alex has a good stock of the Aston calipers  :smiley:
cool, am i missing something re the f40 caliper as was that not used perfectly well on the 370mm kits?  :confused:
« Reply #61 on: August 27, 2014, 03:03:11 pm »
My F40 / 370 kit is great  :happy2:  not sure why Rich went with 362, probably due to the offset of the wheels and the design of the bells
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=ms9i3le3fkviaormldcurd81m3&/topic,19740.0.html
« Reply #62 on: August 27, 2014, 03:27:37 pm »
I don't think the 370mm discs are available anymore.
There has been 2 sets of f40 calipers with problems. Mine which were refurbished and montes which came off Alex's VRS. The were fine on the VRS but as soon as they were fitted to the golf they suffered the same effect as mine. I.e jamming pistons.
Plus. The brackets that I had on with the f40 calipers were IMO rubbish and sat the caliper/pad too far out (presumably they were for the 370mm disc not actually for the 362mm)
I am much happier with these now. The pads sits perfectly on the edge of the disc.  :happy2:
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #63 on: August 27, 2014, 04:49:54 pm »
Rich - as they are fully floating, any rattling at all?
« Reply #64 on: August 27, 2014, 05:05:53 pm »
None.
Offline Biano44
  • The CC GT 200
« Reply #65 on: August 27, 2014, 05:18:36 pm »
Having had my TTRS calipers/ TTS discs fitted a couple weeks ago I can categorically say these brakes are immense and far better Stronger than the NQSBBK  I had fitted to the Golf.
If I had any complaints, the RS4-2's are still quite aggressive compared to the DS2500 I'm used to.
« Reply #66 on: August 29, 2014, 02:08:55 pm »
Added a missing photo to the first post and an started to do a mini review
Offline DaveB@Vagbremtechnic
  • Trader - 2014
  • -Receive: 130
    • Vagbremtechnic.com
« Reply #67 on: August 29, 2014, 03:02:42 pm »
Rich without wanting to hijack your thread thats really quite inaccurate (wrong!). The caliper bracket for the F40 caliper is actually configured for the 362 and then it had a laser cut machined plate installed with longer bolts to actually adapt the kit to the 370mm rotor, the 362mm/370mm discs are the same offset on purpose.....cant think why
In addition race pads are notoriously inaccurate in manufacture, this is why when kits are manufactured its always done with NEW bearings/discs and OEM pads. You have to have a datum somewhere, Pagid are the worse for shape thickness and alignment, Mintex are the best....
IMO of course
« Reply #68 on: August 29, 2014, 03:22:46 pm »
Ok... well thats just what I found and saw and presumed wrongly then. Must just be the pads inaccurate manufacturing... either way it wasnt right. However the RS42 pads in the DB9 calipers fit perfectly on the edge of the disc.... maybe just a fluke?  :confused:
Sadly dont have pics, but I would say they over hung 3-4mm on the F40s (hence me wrongly presuming 370-362 = 8mm/2 = 4mm overhang )
Anyway.... all I will say is these so far (touch wood) have been problem free.
« Last Edit: August 29, 2014, 03:34:36 pm by richwig83 »
Offline vRSAlex
  • -Receive: 253
« Reply #69 on: August 30, 2014, 08:07:44 am »
Was about 1mm overhang at the worst point. Mainly as that Brembo F40 caliper is designed for a smaller disc so it's really the pad shape that makes it overhang.
Follow AKS tuning on Facebook
« Reply #70 on: August 30, 2014, 08:20:24 am »
Offline GS WAX
« Reply #71 on: August 30, 2014, 04:49:08 pm »
Fantastic set up and look good value all things considered.
 Going to copy you soon only with the 340mm discs for now,had a look at one of those calipers today... simply gorgeous,if Alex wasn't going on Hol he would still be there fitting them now :smiley:  pics really don't do them justice,Pass the Kleenex... :grin:
Hopefully I wont need more than 8mm spacer with my Glendales,or we will be poxed
Rich,How are they with general commute style driving? noisy,squeaky etc. i'v driven DB9's/Vantage and they seen pretty normal oem ish on the brakes.
Also anyone know the weight of a Stock (312mm or whatever it is) gti caliper?
« Reply #72 on: August 30, 2014, 05:19:46 pm »
Well, to my surprise they are very well manoured. Pretty much silent except the wirring from the slotted rotors when braking hard. You won't get that if you use plain discs.
« Last Edit: August 30, 2014, 05:48:54 pm by richwig83 »
« Reply #73 on: September 01, 2014, 09:50:39 am »
OEM Rotors 312mm (7.75 kg)
OEM Caliper & Carrier (5.5kg)
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #74 on: September 01, 2014, 10:10:07 am »
Took me a while to get used to that, i was plaguing Alex, convinced that the pad clips were rattling  :chicken:
