Author Topic: ABS light on ...  (Read 6880 times)
Offline ARV_90
ABS light on ...
« on: August 13, 2014, 01:09:39 pm »
A friend of mine has just rang to ask if I will scan his mk5 gt as he says his ABS light has just popped up and stayed on... Could this be the dredded ABS pump... Cheers.
Offline marko
Re: ABS light on ...
« Reply #1 on: August 13, 2014, 01:54:20 pm »
If i remember correctly...the traction light will also stay on if the pump is the problem
Get the car scanned for the g201 fault
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #2 on: August 13, 2014, 01:56:15 pm »
I bet its a loose seat airbag wiring. Quite common but only way to confirm is with a scan
Offline ARV_90
« Reply #3 on: August 13, 2014, 03:10:19 pm »
Ah forgot about the wiring under the seat... Will do a scan for him and see what comes up.
Offline ARV_90
« Reply #4 on: August 13, 2014, 07:11:40 pm »
Car is an 04 GT  Did a scan and came up with this  :scared:
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0103
   Coding: 0023170
   Shop #: WSC 01279 785 00200
   VCID: 3A7F36DB0CCF
1 Fault Found:
01435 - Brake Pressure Sensor 1 (G201)
            012 - Electrical Fault in Circuit
Offline ARV_90
« Reply #5 on: August 13, 2014, 08:47:35 pm »
http://wiki.ross-tech.com/wiki/index.php/01435#01435_-_Brake_Pressure_Sensor_1_.28G201.29
 01435 - Brake Pressure Sensor 1 (G201): Electrical Fault in Circuit
Possible Causes
    Brake Pedal Switch (F) faulty/jammed
    Brake Pressure Sensor 1 (G201) faulty
Possible Solutions
    Check/Replace Brake Pedal Switch (F)
        See Measuring Blocks
    Check/Replace Brake Pressure Sensor 1 (G201)
        ABS Hydraulic Unit (N55) may need to replaced
        Perform Brake Pump Bleeding
        Perform Brake Pressure Sensor 1 (G201) Basic Setting
        Replace Brake Electronics Control Module (J104)
Thanks for the info... worth doing a few checks  :happy2:
« Reply #6 on: August 13, 2014, 09:16:55 pm »
http://www.ecutesting.com/vw_golf_touran_abs_pump_module.html
I believe VW now have a kit available to fix this as well. Much cheaper than a new ABS unit.
Here is a how to http://www.briskoda.net/forums/topic/190784-how-to-repair-espabs-fault-with-vag-repair-kit/
« Last Edit: August 13, 2014, 09:20:30 pm by bacillus »
Offline Monkey10
« Reply #7 on: August 13, 2014, 09:33:08 pm »
Hi, vw now usually cover this under warranty if it's the G201 sensor fault. Vw now do a kit that replaces the hydraulic part of the abs unit. They'd have to do the initial check to follow warranty procedures as long as this is the fault then it should be covered! Give your local dealer a call :happy2:
Offline Dannyboy88
« Reply #8 on: August 13, 2014, 10:02:14 pm »
Ive got this fault on my jetta, happend today, was driving along then noticed the ABS and Traction light up, drove home turned the car off and back on now only the ABS light is on? Havent taken it out since but my guess will be the traction light will come back on. Hope its not going to cost an arm and a leg as i really cant afford it :-(
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #9 on: August 13, 2014, 10:22:28 pm »
when this happenned on mine i went to bba reman who gave me a reconditioned unit for around 100quid with a lifetime warranty
Offline marko
« Reply #10 on: August 13, 2014, 10:42:01 pm »
Done this on mine earlier this year at a cost of around 150 euro
Few vw dealers on ebay that supply them
Offline ARV_90
« Reply #11 on: August 13, 2014, 11:04:36 pm »
Thanks for all the info guys, I have passed on the good news about the repair kits and reman units, Made him feel a bit better as he has been told 4 figures to repair it...  Not sure VW will want to know as it has no VW service history, But you never know it may be worth a try.  :smiley:
Offline Monkey10
« Reply #12 on: August 14, 2014, 07:20:30 am »
Fitted a repair kit yesterday to a 57 plate jetta with only first service Vw. 89k on clock and was covered so worth a try.
Offline Dannyboy88
« Reply #13 on: August 15, 2014, 03:22:03 pm »
Fixed mine today, got it scanned with vagcom, it was the rear right abs sensor on mine.
